Results 1 to 15 of 15
Thread: Sena and 10u issues
  1. #1
    Join Date
    Mar 2016
    Nottingham
    Posts
    1,856
    Sena and 10u issues
    Guys,
    Friend has Nav 4 and has just bought a Sena 10u. I have Nav 5 and Sena 10u.
    We have now had 3 attempts at getting his set up, mine is fine.
    We are trying to set up so he can hear his Nav 4 directions through the helmet and talk via intercom. For the life of us we cannot get the satnav turn instructions to come through the unit. Have done a search and followed what I can find without success. He has a iPhone 6.
    Can someone post a step by step guide as we are at the stage of throwing it at a. Wall
  2. #2
    Join Date
    Oct 2015
    Cambridge
    Posts
    295
    Have you tried deleting all pairings from phone - nav - sena and starting fresh ?
  3. #3
    yeah , turn them all off and do a restore on your mates ...then .turn on the sena , turn on the nav ( make sure yours are off or well out of the way as the nav might look for your sena etc ) they should then pair ,Headset to nav. That is the basic set up ....when that is done you can try to pair your headset to his ,I have not actually done that, but its in the set up guide in the Sena handbook which you can download
    Good luck
  4. #4
    Join Date
    Mar 2016
    Nottingham
    Posts
    1,856
    Thanks chaps. The issue is not pairing to mine though.
    We can't get his satnav instructions to come through the headset?
  5. #5
    Quote Originally Posted by Wonkey donkey View Post
    if the headset and nav are pairing ,but no sound, on the nav go to volume, touch the spanner in the top left corner ,then audio mixer, ,three blue bars appear ,is the Nav one set to the right for loudness ?
  6. #6
    Join Date
    Mar 2016
    Nottingham
    Posts
    1,856
    Volume ok on nav4 totally confused of why sound not coming through Sena in helmet?
  7. #7
    Join Date
    Mar 2016
    Nottingham
    Posts
    1,856
    Have emailed Sena to see if they can help out, will post on here as may help others later
  8. #8
    Join Date
    Apr 2006
    Lea & Perrins country.
    Posts
    2,039
    I bought a 10U for my Schubert and setting up was a dream. Bought another one for my Arai and its gone back! Under no circumstances would it pair!
  9. #9
    Join Date
    May 2004
    Cardiff, Wales
    Posts
    1,598
    see manual for exact sequence but
    do a reset on the sena 20s, involves paperclip and small hole in sena! go to config menu and reset all to factory (this is what the company will teell you to do as a start point)
    check vol on sat nav not muted (you say vol ok but possible a mute "box" in menu somehwere been checked?)
    Had a similar issue with sena 20s and 590, a simple turn sena off, and then back on again, actually worked!
  10. #10
    Join Date
    Mar 2016
    Nottingham
    Posts
    1,856
    Quote Originally Posted by russ996duke View Post
    Volume is not muted. We have set up a dummy trip and you can hear the Nav iv directions but coming from its speaker not through the headset. Have tried deleting all pairings etc etc. Damned if I know what's bloody up with it.
  11. #11
    Join Date
    May 2004
    Cardiff, Wales
    Posts
    1,598
    This does sound like it could be an issue with nav 4 rather than the sena, does the nav 4 show the sena as paired in the bluetooth menu?
    if it does show as paired, reckon the sena is faulty, if you contact sena via website to return under warranty you need to tell them that you have already tried procedure I describe in post 9 , they should then give you a return number to send it back with to your supplier
  12. #12
    Join Date
    Mar 2016
    Nottingham
    Posts
    1,856
    I am inclined to agree. Phone pairs Nav ok, phone pairs to Sena ok tried just to see, but keep getting Nav saying cannot connect even though they appear to find each other on Bluetooth.
  13. #13
    Join Date
    Jan 2014
    Gloucester United Kingdom
    Posts
    1,454
    Have you tried pairing your headset to his nav unit, and his headset to your nav ?
    Might solve whats not working.
  14. #14
    Join Date
    Mar 2016
    Nottingham
    Posts
    1,856
    Quote Originally Posted by Gargy View Post
    Hi Gargy
    No as I go to Spain on Tuesday and don't want to mess around with mine in case I fcuk it up. Works perfectly.
    Will do when Get back.
  15. #15
    Join Date
    Mar 2016
    Nottingham
    Posts
    1,856
    Well tried everything and every way we can think of to get the Nav iv to pair to the Sena. All we get is a message saying unable to connect, why god only knows.
    Phone to Nav is fine and pairs every time we have tried but the Nav to the Sena is def the problem. If I can get them to pair sure it will work but ran out of idea's
Posting Permissions
  • You may not post replies
  • You may not edit your posts
