Page 1 of 2 12 LastLast
Results 1 to 16 of 18
Thread: K1600 GT reverse gear
  1. #1
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,636
    I had a very brief go, sitting on a new bike, with the reverse gear. It's initially quite an unerving experience.
    Lift the bike to upright, if it's not there already.
    Raise the side stand, if it's not already up
    Start the engine, if it's not already running
    With the bike in neutral, push the button R on the left hand bar. R will appear in the gear position indicator screen
    Push the starter button....
    Nothing will happen for a moment.... Then the rev's will rise.... that is a bit unnerving at first as it sounds as if the bike is about to speed off.... and the bike will then drive - under engine power, not just on the starter motor- backards at a reasonable pace. Lift your thumb off the starter switch and the bike will stop, the engine still running. Push it again and the rev's rise again and back it goes. Repeat until happy.
    Once you get used to the noises and how it drives backwards it's quite easy.... a useful addition to a heavy bike, particularly if you are on gravel or having to pull it up a slope.
    Next... feet up reversing!
  2. #2
    Join Date
    Oct 2016
    somewhere in time or Musselburgh
    Posts
    1,674
    Would it not just be easier for you to get your man servant to push it backwards ?
    Sent from my GT-N7105 using Tapatalk
  3. #3
    Join Date
    Sep 2003
    Norwich
    Posts
    1,280
    All it needs now is an auto box.
  4. #4
    Join Date
    Oct 2008
    Drigdale
    Posts
    7,179
    Ah - I had assumed it was a battery powered function.
    Don't press R going around a corner - there will be 50 pages of investigation.
  5. #5
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,636
    The bike would indeed lend itself well to a good, dual clutch, auto engine.
  6. #6
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,636
    Quote Originally Posted by Cooperman View Post
    I had assumed the same. It does though make very good sense to have the engine driving the heavy bike backwards, saving the battery and starter motor possibly straining away. I guess you could, if you felt the pressing need, drive backwards for several hundreds of yards, just as you can in a car.
  7. #7
    Join Date
    May 2004
    Wirral
    Posts
    14,265
    Quote Originally Posted by Wapping View Post
    Do tell...what made it rise ?
    Bicycle riders.....Darwin's very own speed bumps.
  8. #8
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,636
    Excitement..... and the arguably unnecessary foreshortening of revolutions, the word revs itself having entered common usuage.
  9. #9
    Arse Click here to find out how to Subscribe
    Join Date
    Apr 2010
    Terra Firma
    Posts
    4,966
    Quote Originally Posted by Tarka View Post
    what made it rise ?
    Yeast
  10. #10
    Join Date
    Jan 2002
    Redditch, Worcs
    Posts
    6,943
    Sounds no different from the reverse function I had on a K1200LT a few years ago, very straightforward when you get used to it.
    2010 BMW R1200GSA
    2017 Kawasaki Z1000SX Touring
    2007 Suzuki Bandit 1250S
    1989 Jaguar XJS 5.3 Convertible
  11. #11
    Join Date
    Oct 2016
    Bedfordshire, England
    Posts
    660
    Absolutely - personally I would prefer to see the K16 with a Honda style DC auto option in preference to this fangled reverse thingy, particularly as the original gearboxes have been problematic for some. Still, I guess when the bike is fully loaded there is a case for reverse, as with the Wing, but doesn't everything just start to get too heavy & over-complicated. The K16 already needs to go on a serious diet.
  12. #12
    Join Date
    Oct 2008
    Drigdale
    Posts
    7,179
    Quote Originally Posted by squibb34 View Post
    It is a brilliant bike for uber two up touring whilst at the same time being able to get some real performance.
  13. #13
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,636
    No gearbox problems on either of mine..... nor any need to take it to Hilltop.
  14. #14
    Join Date
    Jan 2002
    Harpenden
    Posts
    9,087
    I've seen one being reversed... It's quite a noisy commotion!
    I think you'll find that the revs rise so that the alternator is generating sufficient juice to provide/replace the power being used as the starter motor is used to reverse you.
    Sell my bike?
    I would rather stick wasps up my arse !
  15. #15
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,636
    Quote Originally Posted by Wreford Miles View Post
    Aha, that makes perfect sense.
  16. #16
    Join Date
    Aug 2010
    Paradise
    Posts
    21,082
    Burn the witch
Posting Permissions
  • You may not post replies
  • You may not edit your posts
