Page 2 of 3 FirstFirst 123 LastLast
Results 17 to 32 of 44
Thread: K1600 GT reverse gear
  1. #17
    Join Date
    Sep 2012
    Torbay, England
    Posts
    26,875
    With the seat high enough to get properly comfortable, retracting undercarriage would make the bike usable and comfortable for anyone regardless of leg length.
    08 R1200GSA
    76 Suzuki GT750
  2. #18
    Join Date
    Jan 2009
    Co. Meath Irish Rep.
    Posts
    5,060
    Quote Originally Posted by Wapping View Post
    Aha, that makes perfect sense.
    No the cam timeing changes and the engine runs backwards. JJH
  3. #19
    Senior Member
    Join Date
    Oct 2008
    Drigdale
    Posts
    7,769
    Have not been on the K1600 forum for a while.
    Sounds like there is a problem with the reverse gear. If you turn off in reverse gear the gear box will only allow upwards changes.
    BMW have acknowledged the problem and a fix was on the way.
  4. #20
    Senior Member
    Join Date
    Sep 2017
    Thoughts hashtags and candles
    Posts
    1,733
    Quite why it needs a thread of its own to describe the blindingly obvious baffles me !
    Seriously if you are curious, just borrow one from your dealer for a morning/afternoon.
    A seriously good bike. Just a shame the choice of colours is a smidge weird ... and there are a couple of things that irk .. like the stupid “aerial” and the number 6 plastered everywhere (is it just to impress teenage boys FFS)
  5. #21
    Senior Member
    Join Date
    Mar 2003
    Runny eggs and strangers, white lines and unmade beds.
    Posts
    21,425
    Only just seen this.
    I'm almost certain it is an electrical drive in reverse, not an actual reverse gear. Revs to produce enough electricity.
    I can't say I've ever missed reverse gear, and the only time I had ro reverse uphill (on K1200GT) I asked pillion passenger to get off and push!
    I love my K1600 but have to admit the new lighter and DCT Gold Wing is starting to look appealing... lighter is a relative term only. It is still quite a lot heavier than the already heavy K1600GT
  6. #22
    Senior Member
    Join Date
    Sep 2017
    Posts
    1,733
    Shame Kevin Ash is no longer around to describe the technology they implemented.
    Quinton ... surely the biggest problem with the Gold Wing (apart from the stupid weight) is the ridiculousness of the pricing structure?
  7. #23
    Join Date
    Mar 2011
    Diss,Norfolk
    Posts
    7,048
    Quote Originally Posted by Quinten View Post
    I am sure I read that it uses the starter motor for the reverse motion
    I have not tried a new one but I really have never had an issue with the bike weight maybe I am just more of a man than you
  8. #24
    Senior Member
    Join Date
    Sep 2017
    Posts
    1,733
    I had a very brief go, sitting on a new bike, with the reverse gear. It's initially quite an unerving experience.
    Lift the bike to upright, if it's not there already.
    Raise the side stand, if it's not already up
    Start the engine, if it's not already running
    With the bike in neutral, push the button R on the left hand bar. R will appear in the gear position indicator screen
    Push the starter button....
    Nothing will happen for a moment.... Then the rev's will rise.... that is a bit unnerving at first as it sounds as if the bike is about to speed off.... and the bike will then drive - under engine power, not just on the starter motor- backards at a reasonable pace. Lift your thumb off the starter switch and the bike will stop, the engine still running. Push it again and the rev's rise again and back it goes. Repeat until happy.
    The OP sounded as if he was aghast ... “wide-eyed” at the technology... at least some understand it’s electric. It is certainly NOT “engine “ driven as the OP thought ! (Twat )
    Quinten and Norfolk Tiger grasp it ....
  9. #25
    Senior Member
    Join Date
    Sep 2017
    Posts
    1,733
    Quote Originally Posted by JJH View Post
    From anyone else I’d see this as attempt at humour ... but I suspect you possibly believe your post !
  10. #26
    Join Date
    Sep 2012
    Torbay, England
    Posts
    26,875
    Quote Originally Posted by Charles Martel View Post
    Of course not. Everyone knows it’s got a little stinkwheel engine rubbing on the back tyre.
    08 R1200GSA
    76 Suzuki GT750
  11. #27
    Senior Member
    Join Date
    Sep 2017
    Posts
    1,733
    The bike does NOT drive rearward under engine power ;
    That would be nuts ! And need involvement of the clutch ...
    The starter now has “two ends” one for turning the crank in the normal way ..The additional gear on the “other “ end of the starter simply rotates a gear in the transmission.
    This only works when the engine is running. The sprag clutch on the engine side will not lock up, because the engine is running faster than the starter gear.
    It’s an ingenious method to us the same motor for two
    purposes.
  12. #28
    Senior Member
    Join Date
    Sep 2017
    Posts
    1,733
    Similar technology is being used in VW cars where the electrics have moved to 48V from 12V.
    The starter motor is now powerful enough to drive the car (forwards this time Wapping!! Do keep up ! ) to supplement the petrol engine for extra acceleration or drive the car slowly in cities with no petrol intervention.
  13. #29
    Join Date
    Oct 2016
    Bedfordshire, England
    Posts
    828
    Here is a diagram of the system on the K16 .......... http://www.mcnews.com.au/wp-content/...e-1024x706.jpg
    Looks like what it is, a horrid bolt on device that shouts out for proper integration. Many owners, including those with the new bagger K1600B, have had problems - it's noisy when actuated, some have got stuck in reverse, some have sheared the gear wheel at the starter, some have found they can't downshift below 3rd gear. The Mothership appear to have addressed the issues, but with the bagger aimed at new conquests in the US, one would have expected better at this pricepoint.
  14. #30
    Join Date
    Oct 2016
    Posts
    828
    Whilst I haven't tried it personally, I gather it doesn't like reversing the bike up a slope. I suspect the noise comes from over-stressing & so damaging the gears at each end of the flexi-drive - looks like a pinion & crown wheel at the starter & a worm drive to the shaft. Any undue noise & warranty will be needed.
  15. #31
    Join Date
    Sep 2012
    Torbay, England
    Posts
    26,875
    Quote Originally Posted by squibb34 View Post
    BMW do have a penchant for afterthought ideas. Surely they could have worked out from day one that a reverse gear was going to be needed. Goldwings have had them for years.
    08 R1200GSA
    76 Suzuki GT750
  16. #32
    Senior Member
    Join Date
    Sep 2017
    Posts
    1,733
    Squibb ! Loved the pic on the link !
    I agree with your comments.
    Ps Maybe Wapping will believe me now they it’s electric motive power not the engine ! .
    I won’t hold my breath !
Posting Permissions
  • You may not post replies
  • You may not edit your posts
