Front brake fluid replacement
Tacho D
Norwich
Hi guys, I seem to get conflicting info about changing the brake fluid on a 2004 gs with ABS. The Haines manual recommends dealer only while elsewhere others have tackled it themselves without issues. Is there a special procedure, or should i leave well alone? I am about to change front pads, (Brembo) so thought I would have a go at changing the fluid. And is it possible to replace pads without removing the calliper? Any advice welcome.
I know this post is a few months old so ignore if you are sorted.
I have a 2006 twin spark and do all my own maintenance. Brake fluid change is easy and I then connect the GS911 to bleed the ABS unit.
There are alternative methods just visit the chain gang FAQ`s on www.f650.co.uk.
Hope this helps
Paul
