Page 1 of 3 123 LastLast
Results 1 to 16 of 41
Thread: Bullet Camera
  1. #1
    Join Date
    Dec 2014
    Dorset
    Posts
    127
    Bullet Camera
    Just wondered if anyone has tried this camera package or any thoughts?
    http://www.4kam.com/bike_camera_moto...m_packages.htm
  2. #2
    Join Date
    Jun 2003
    Romford Essex
    Posts
    1,838
    Hi I looked for a decent camera for ages, I wanted one that came on with the Ignition and recorded straight away, not for videoing the trip but purely in case I got taken out buy some Idiot but could not find anything that was reliable that didnt run from batteries, I saw this one (Linky below) and gave it a try and have to say its excellent I put a 16g card in it which lasts about 4 hours on high res longer on 720p but it suites me fine also bought one for my son in law who put it on his Africa Twin
    did a weeks tour around Ireland couple of weeks ago and it worked superbly, 10 hr ride home in the lashing down of rain and no problem at all, well worth the money easy to fit and set up has wifi and an app for your phone or smart arse device which really works !!
    Anyway heres the link
    Rob
    http://www.ebay.co.uk/itm/Nextbase-R...72.m2749.l2649
    Knowledge is knowing a Tomato is a fruit, wisdom is not puting it in a fruit salad
  3. #3
    Join Date
    May 2006
    Southampton
    Posts
    1,616
    I've got the nextbase ride as well, hard wired onto my bike with a 64gb card, works really well, the rest of the guys on my European bike trip like to see videos of them on the twisties.
  4. #4
    Join Date
    Jun 2003
    Romford Essex
    Posts
    1,838
    Sorry my card is a 64g not 16
  5. #5
    Join Date
    Apr 2009
    Essex
    Posts
    254
    Next question is likely to be, how have you got those mounted, fairly chunky so interested to know.
  6. #6
    Join Date
    Jun 2003
    Romford Essex
    Posts
    1,838
    Mine is mounted off the indicator bolt on a little L bracket I made very sturdy no vibrations at all can post a pic if you want one
    Rob
  7. #7
    Join Date
    Oct 2015
    Cambridge
    Posts
    293
    Nextbase spec 32GB how do you get it to accept 64Gb ?
  8. #8
    Join Date
    May 2006
    Southampton
    Posts
    1,616
    Quote Originally Posted by Chicken View Post
    Bought a nextbase 64gb card in Halfords on advice from tech guy at nextbase.
    Attached Images Attached Images
  9. #9
    Join Date
    Jun 2003
    Romford Essex
    Posts
    1,838
    Quote Originally Posted by diplomaticdanny View Post
    Same as that
    the instructions actually say max is 32gb which will give 4 Hrs recording @1080p so Im assuming the 64 will give 8Hrs but ive not tested that theory out so looks to be about 12Hrs in 720p thats long enough for me I think id realise if I had an accident by then LOL
    another feature its got is if it feels an accident it saves that part of the video so it cant be recorded over but if its set to low or medium it just fills up the memory with saved video every time you go over a bump !!
    I turned that feature off its recording so didnt think i needed that !!
    It also records your speed everywhere so id be careful should you get pulled by a clued in Police officer this feature ive not been able to turn off
    Rob
  10. #10
    Join Date
    Jun 2007
    Galway Ireland
    Posts
    4,125
    Would be better with a stelth mounting, discretely out of view. I think I will put one on the RT
  11. #11
    Join Date
    Jun 2017
    Midlands
    Posts
    278
    I've taken a swing on the Nortek Bike Pro http://www.nortek.co.uk/bike-bro-dua...otorcycle-dvr/
    Avoids canbus issues by having a smart power unit that senses vibration e.g. when the engine is running, so that power drain only occurs when the engine is running.
    Not installed yet.
  12. #12
    Join Date
    Jun 2007
    Galway Ireland
    Posts
    4,125
    Quote Originally Posted by yofi View Post
    Not installed yet.
    That's more like it. Looks good.
  13. #13
    Rum Bosun Click here to find out how to Subscribe
    Join Date
    Mar 2017
    Pewsey, Wiltshire
    Posts
    270
    Cameras
    I have the INNOVV K1 system fitted front/rear on my bike and can heartily recommend it. Www.innovv.com you can buy direct from the manufacturer
    A lot of good cameras out there, but they all seem both bulky and "visible". The camera heads on this unit are fully waterproof and they don't stand out at all. There is no requirement to take them off when you stop. The system records in HD and as there are 2 cameras, you get front/rear POV. It's all linked to GPS and if you prefer, there is an on/off switch rather than having the system running all the time the bike is powered.
    You do, though, have to make or adapt some form of bracket for each camera (I can send a drawing of my brackets if you want them) the cameras have a standard "camera threaded hole" (1/4" whitworth?) on 3 sides
  14. #14
    Join Date
    May 2006
    Southampton
    Posts
    1,616
    Quote Originally Posted by Adventure Boy View Post
    Same as that
    Rob
    I think you push menu twice to access speed recording options.
    I have turned mine off.
  15. #15
    Join Date
    Dec 2014
    Dorset
    Posts
    127
    Not installed yet.
    This looks like the one I found, ish! The cameras are small and discreet. Also looks like you can get extra cameras with long leads so car installation might be possible too? When you install can you post info please?
  16. #16
    Join Date
    Dec 2014
    Dorset
    Posts
    127
    Quote Originally Posted by Phill Elston View Post
    I've been looking at these already but am not sure I can fit the recorder unde my seat. I already have a hex ezcan and the associated leads under the seat so not much room left. Where have you put the recorder on yours?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
