Results 1 to 15 of 15
Thread: iPad won't charge
  1. #1
    Join Date
    Jan 2007
    Central Scotland - no more far away
    Posts
    1,682
    iPad won't charge
    I foolishly let my iPad 2 battery run down and now "It Just Won't Charge".
    I've searched online and the hints and tips point to the usual reset button pushing exercise or looking at alternate charger plugs and cables.
    I've done this and it simply looks like the power connection in the iPad socket is not well.
    I can see a minimum (zero) battery level (red) and waggling the cable in the socket can make the lightning symbol appear for a second or 2.
    And sometimes it will sit for hours - make that days - with the white Apple symbol on the screen. But zilch. Nada. Nothing.
    Is it terminal?
    Do I have to resort to an expensive shop repair? (Where? How much?)
    Or do I kiss it goodbye to the apple warehouse in the sky.
    Carpe Diem!
  2. #2
    Join Date
    Jan 2009
    Co. Meath Irish Rep.
    Posts
    5,321
    Are you using the bigger iPad charger? And a genuine Apple lead? JJH
  3. #3
    Join Date
    Nov 2010
    Hamburg, Germany
    Posts
    2,120
    The Lightning cable/plug isn't the best/strongest design, so I would find an Apple shop or dealer and ask them to try a known good Lightning cable and Adapter.
    I think if you had a non genuine Apple Lightning Cable, then the iPad would report that it was not genuine. This happened to me when I bought a Lightning cable from an Amazon UK dealer. The Apple shop in Hamburg confirmed twice that it was a fake, but refused to put it in writing and the Amazon UK shop insisted their fake cable was genuine (bunch of crooks).
    Apple can exchange your iPad for a refurbished iPad of the same type, if the new Lightning cable doesn't resolve the problem. However, like all Apple gear, it is hopelessly overpriced in my experience.
    Grey Beard
  4. #4
    Join Date
    Jan 2009
    Posts
    5,321
    My experience of non genuine lightening cables is some work some don't. Some report as not comparable or some such and some stop working after an upgrade. I speak from experience as there are 5 iphones 3 iPads and a Mac mini + many old iPhones lying around the house. I was an early adopter having graduated from iPods. JJH
  5. #5
    Destined to come last Click here to find out how to Subscribe
    Join Date
    Feb 2010
    'arrow, near the 'ill.
    Posts
    1,266
    If you have the lightning plug, have a peek at the metal strips on the tip. My wifes ipad stopped charging because one of them went awol.
    Brian
    GSA Triple Black
    VW 'Triple Black' Campervan
    Zagato Guzzi 950 cafe
    Guzzi Le Mans 2, black and gold Coburn and Hughes
    Ducati 996R
    You may say I'm a dreamer, but I'm not the only one
  6. #6
    Join Date
    Sep 2008
    Castor, Cambridgeshire, England
    Posts
    5,380
    anker supply very good cables.
    In fact I reckon they are superior quality to the oem.
    much cheaper too.
    Never had any issues with them being recognised by devices.
    For under a tenner its worth a punt
  7. #7
    Join Date
    Jun 2015
    South Yorkshire
    Posts
    89
    Hi I have sent you a Pm..
  8. #8
    Join Date
    Jun 2006
    Islandmagee, Co Antrim NI
    Posts
    9,590
    clean your lightning connector hole GENTLY with a toothpick
    Its a fairly well known issue
    Oh Great and Wise Deity, Grant me the serenity to accept the things I cannot change,
    Courage to change the things I can! And the wisdom to know the difference!
  9. #9
    Strawberry fields ... forever Click here to find out how to Subscribe
    Join Date
    Aug 2003
    West Devon
    Posts
    7,200
    I had a similar issue with an iPhone 5, but it was quite old so I bought a replacement; then my s-i-l commented that it was a common issue and cleaned out the charge port with a paper clip, upon which normal service was resumed. Might be worth a try ?
    Paul
  10. #10
    Join Date
    Jun 2006
    Posts
    9,590
    Quote Originally Posted by oblertone View Post
    Crikey you were lucky there! (unless it was a plastic covered clip?)
    Try to avoid metal and sharp edges etc Use a wooden cocktail stick or toothpick or similar
    Also avoid cotton buds as they can leave lint in the port which apparently is the cause of the problem
  11. #11
    Join Date
    Jun 2012
    derby england
    Posts
    1,901
    if you can use a can of compressed air and something plastic to loosen any compacted dirt then blow it out.
  12. #12
    Join Date
    Jan 2007
    Posts
    1,682
    Thanks for all the above. Including an offer to "have a go at it".
    I'll keep swapping cables and plugs, etc. and have a gentle prod in the connector(s).
    I hadn't consider a part/ex option. It is 5 or 6 years old.
    Carpe Diem!
  13. #13
    Fat Bikers Bounce Better Click here to find out how to Subscribe
    Join Date
    Jan 2006
    Coggeshall, Essex
    Posts
    2,923
    Apple Support: 0800 107 6285
    Arrogant Patronising English scum living the dream ...
  14. #14
    Join Date
    Dec 2006
    Scotland
    Posts
    4,004
    I had the same issue with an iPhone 4s. When the battery discharged so far it would not accept a charge. The recommended fix was to heat the phone with a hair dryer to raise the temp of the battery then plug it in and recharge normally. Don't know if this works with an iPad but no harm in trying.
  15. #15
    Join Date
    Sep 2012
    Torbay, England
    Posts
    27,448
    iPad won't charge
    Click here to find out how to remove these ads
    My 2012 MacBook has the original battery. A couple of months ago I noticed a fall off in battery life then it refused to charge. I bought a new Apple battery then Lo & Behold the old battery started working again.
    It might be a software glitch or maybe the battery has failed. They are not as easy to replace on a pad but a half decent service/repair shop will do it.
    08 R1200GSA
    76 Suzuki GT750
Posting Permissions
  • You may not post replies
  • You may not edit your posts
