Results 1 to 6 of 6
Thread: Pinking - R1200RT LC
  1. #1
    Member
    Join Date
    Jul 2017
    Somewhere in England
    Posts
    68
    My bike has been pinking from new. Initially I thought it was because I was using lower octane petrol during running in (less lubricity), but it continues even with Shell's finest.
    I was brought up to perceieve pinking as a cause of engine damage.
    I'm guessing it's a side effect of Euro 4 but am worried about my engine - should I be?
  2. #2
    Hugh Janus Click here to find out how to Subscribe
    Join Date
    Apr 2014
    Kent
    Posts
    601
    Mine (late 2015) doesn't pink at all, so I'd suggest a chat to dealer to see why it does and what can be done about it.
  3. #3
    Join Date
    Jan 2009
    Co. Meath Irish Rep.
    Posts
    5,190
    Pinking (pre ignition) will cause engine damage. So is it pinking? Who diagnoised it? Are you sure? If it is it needs to be sorted. Bmw are renownd for their knock sensors so it shouldnt be pinking JJH
  4. #4
    New Member (less than 15 Posts)
    Join Date
    Sep 2013
    Blackpool. U.K.
    Posts
    11
    I had a R1200RT LC when they first came out and that pinked badly from new. Dealer said it was normal but that and a terrible gearbox led me to get rid as soon as I could afford to. I don't think the any lc motors have knock sensors fitted. Surprisingly my current bike a 2015 gs does not pink unless I use the wrong fuel (super unleaded is not always available abroad) and since I had a new engine fitted for corrosion issue's the gearchange has been vastly improved. The tag from the engine that the dealer gave me said it was a late 2016 unit.
    Sent from my LG-H815 using Tapatalk
  5. #5
    Join Date
    Jun 2008
    Cheltenham
    Posts
    2,246
    Book a session with Geoff.
    http://www.hilltopmotorcycles.co.uk/
  6. #6
    Quote Originally Posted by Martyn H View Post
    I wouldn’t – he dials in timing advance, which relies heavily on the knock sensors. If you’re getting pre-ignition now maybe the knock sensors are suspect and more advance will make it worse.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
