Page 2 of 3 FirstFirst 123 LastLast
Results 17 to 32 of 36
Thread: Speccing a new RT up
  1. #17
    Join Date
    Feb 2016
    Salisbury, England
    Posts
    617
    You can buy the bits to put a cubby hole on the right if you want, not cheap, but depends on the value you put on having it
  2. #18
    Join Date
    Feb 2010
    Nearby
    Posts
    782
    Thats great info., definitely the USB lead on the RHS cubby hole I need (so +Radio).
    I wonder when the 2018 Goldwing will get announced
    RBW.
    Quote Originally Posted by DC View Post
    just to confirm ....on a Non Audio bike you get a cubby hole on the left side. its small but takes an iPod MP3 player.
    on the Audio model, you get a usb lead connected into the bike and it says in the right cubby hole. To this plug in your music player. it can be selected on the Menu and the wheel operates the tracks. If you want to plug in an iPhone...you need the BMW iPhone to Audio system lead ,these are about £50 i think !!!! cheaper ones are available but not sure if the wheel recognises them .
    "The fact is this is about identifying what we do best and finding more ways of doing less of it better" - W1A
  3. #19
    Join Date
    Dec 2004
    Oswestry
    Posts
    1,619
    I'm also interested in ventureshield for protection on my Iconic, just never got time to get it done.
    Forget all these Healthy Foods I need all the preservatives I can get!!!
  4. #20
    New Member (less than 15 Posts)
    Join Date
    Jul 2016
    West Midlands,England
    Posts
    6
    Top Box Lid Painting
    Hi,
    I am waiting for my new rt to arrive,buying it from Rybrook,Wolverhampton,been waiting 7 weeks now.The upside is that it has given me time to get me Farkles ready when the bike arrives.
    I managed to find a used once only,fully wired 49 litre top box,from ebay.I have added the over priced bmw brake light at £148.00,it's easy to fit.
    I have also removed the lid cover,there is no need to take off the entire lid,just unscrew all the screws you can see on the underside of the lid,there you go,lid cover off,15 minutes work.Mines white bytheway.Hope this helps.
  5. #21
    Join Date
    Feb 2016
    Salisbury, England
    Posts
    617
    The problem I found when I wanted one of my panels sprayed, was a lot of paint sprayers are not keen tho get involved in water based paints.
  6. #22
    Senior Member
    Join Date
    Jul 2014
    Over the bridge of sighs
    Posts
    504
    I had the small top box on mine. A good compromise.
  7. #23
    Join Date
    Feb 2010
    Nearby
    Posts
    782
    Nice one Likelylad, Im envious, and white is the most sensible colour to get given the pricing model. I wondered if there would be any 2018 updates, but looks like nothing imminent so no reason to wait (Im still procrastinating though).
    RBW.
  8. #24
    Member
    Join Date
    Jul 2017
    Somewhere in England
    Posts
    68
    Quote Originally Posted by richardbd View Post
    I had audio on my RT.
    £1,000 is a lot of money for a radio and more complexity on the BT front - essentially you have to run two connections, one to the bike for radio and one to the satnav for GPS/MP3.
    If you go non-audio, I wouldn't bank on a functional bluetooth link to the GPS if you use the Schuberth BT. Some will tell you it does work; my experience (with two Schuberth helmets C3 and M1) is that GPS works but MP3 music is intermittent.
    At the moment I wouldn't touch a NavVI with a barge pole, no matter what bike or BT system - read some of the other threads on here. Strikes me instead of a group-buy, somebody should be organising a group-return!
    And don't forget, no audio, no right-hand cubby hole...
    I can confirm, IMHO, that the NAV V1 is the most expensive lump of useless electronics that I have ever bought.
    You can buy the right hand cubby hole as a spare part. Which avoids having a usb cable from 12v socket on right to left hand cubby hole.
  9. #25
    Senior Member
    Join Date
    Sep 2017
    Thoughts hashtags and candles
    Posts
    1,733
    Quote Originally Posted by rainbow-walker View Post
    [*]Am I right to expect some compatibility issues for Bluetooth if I go for the Radio Setup (I have a Schuberth SRC system)
    Which one ? The C3 "neck roll one" ( incompatible with everything in the industry sadly ... YES) , or ( NO) the new C4 R2 one, made by a different manufacturer, which is compatible with everything ( imho).
    I spent 3 days on an RT with my C4 R2 comms and it all worked fine ( whizz - wheel , voice commands, SIRI, ) the lot .....
  10. #26
    Senior Member
    Join Date
    Sep 2017
    Posts
    1,733
    I should probably try one, but the RT itch has been going a while. I assume the RS will be much better at filtering (which is the only worry with the RT).
    RBW.
    Yep , and the RT looks shit with the panniers removed ( imho)
    Its a problem ......
  11. #27
    Join Date
    Dec 2003
    Manchester
    Posts
    1,329
    Quote Originally Posted by Charles Martel View Post
    Let’s face it, it’s not the best looking bike out there, with or without panniers (imho)
  12. #28
    Join Date
    Sep 2012
    Torbay, England
    Posts
    27,249
    Why not hire an RT to see if you really like it. Personally if I had £10000 to lose in depreciation I’d go fo a K16. At least it looks like a very expensive bike.
    08 R1200GSA
    76 Suzuki GT750
  13. #29
    Senior Member
    Join Date
    Sep 2017
    Posts
    1,733
    Quote Originally Posted by Bendy toy View Post
    +1
  14. #30
    Member
    Join Date
    Mar 2008
    Somerset
    Posts
    80
    And then regret it for the rest of your ownership, instead of having a bike that really cuts it in everyday use.
  15. #31
    Join Date
    May 2013
    Cromarty
    Posts
    984
    I tapped into the radio and now have a lead to plug my Shure earphones into, the wheel works the volume control and MP3 track selection, also the radio.
    I got fed up trying to get the Sena volume high enough, I think my Senas were faulty but Sena didn't agree so sold them.
    Are you saying the RT is now a £20k bike ?? can only be good for second hand values.
  16. #32
    Everyone has different tastes and requirements, so ignore all the 'this-or-that is shit!' comments and go with what you want/need
    I just got my new RT this weekend.
    Horses for courses, but I LOVE the look of the RT
    I'd agree that radio is a bit of a waste of money - can't hear it over 50mph anyway, but if you like pottering around and listening to tunes, go for it - I'd have had it if it was (much) cheaper - if you can afford it, there is somethgin to be said for 'having all the toys'
    I'm gonna get my seats and backrest re-upholstered in brown leather, like the Option 719 seats and get some chrome trim bits too
    Contrary to others' comments, I LOVE the topbox - there's something about a carpet-lined, self-opening, internally lit, cavernous topcase of this quality that makes me feel all warm and fuzzy.
    I also have a white RT and love that too - contrary to other's options, it really doesn't look like a police bike (they've been covered in yellow and blue battenberg markings for years!) and I think it makes the bike look slimmer/lighter - I prefer to think it looks like a storm trooper
    I'd agree that having the second right-hand storage compartment with USB would be useful, but not spec'd it for cost yet.
    I went with what I want, not what others opinions told me I wanted and I'm very happy
    This is what I do all day... www.remocreative.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
