Quote (This evening, I planned (or rather attempted to plan) a simple route from Gloucester to Taunton directly on the Nav 6 using the trip planner app. I added a starting point, 11 waypoints and a finishing point. I click 'next' and get "Cannot calculate the route".)
A satnav, that cannot calculate a route, using its own internal app. Just what I wanted when I splashed out £650.
That's it. I'm done with it. It's been nothing but pain every time I've wanted to use it, both with basecamp and without. Total, utter, shite. It's going back for a full refund. Grrrr.[/QUOTE]
This is one way you can build a route using the device, and make sure all points are where you need them to be,
Create a route using shaping points
To create a route with shaping points on the device:
1 Touch Apps
2 Touch Trip Planner
3 Touch New Trip
4 Touch Select Start Location to add a beginning waypoint (Please note that the Start Location is not necessarily the point from where you'll be leaving. The Start Location will be the first point you would like to travel to.)
5 Use the various search options to locate the desired starting point
6 Touch Select
7 Click the (+) Icon to add additional waypoints to the trip
8 Follow steps 5 through 7 to locate and add up to 30 total points ( You must have at least three locations to create a shaping point)
9 Touch the orange flag icon next to a waypoint to turn this into a shaping point
10 Touch Next
11 Enter a name for the trip
12 Touch Done
A new route with shaping points is now saved to Trip Planner
You can also create shaping points in routes created through BaseCamp.
1 Touch Apps
3 Touch New Trip
6 Touch Select
10 Touch Next
12 Touch Done
