The UK's No 1 Motorcycle & Motocross Accessories Store.
Page 1 of 2 12 LastLast
Results 1 to 16 of 20
Thread: Rukka Orivesi suit.
  1. #1
    Join Date
    Aug 2015
    Annan,Scotland
    Posts
    242
    Rukka Orivesi suit.
    Does anyone wear this and can give a review? http://www.tranam.co.uk/product/rukk...-greyyellow-58
  2. #2
    Join Date
    Jul 2004
    Nantwich, Cheshire, England, EU
    Posts
    1,061
    Seems nobody has bought it.
    This will now be your responsibility to review it once bought.
    Sent from Steve's fancy iPad using Tapatalk
    A GOAL is an end toward which some specific effort is directed!
    Go forth and prosper!
  3. #3
    Join Date
    Oct 2016
    Under your bed
    Posts
    216
    Best bet is to check the Rukka site and get their actual name for it.
    They deliberately change the name in the UK to try and prevent eu online purchases so Tranam are not havin to deal with stuff not bought through them. (And increasing their bank balance)
    The Tranam guys are great btw - resolved a few issues with mine without question after the uk dealer decided to be total wankers.
  4. #4
    Join Date
    Mar 2016
    Hertfordshire
    Posts
    1,400
    It is a rebranded Pajaine Suit with an addition of two pockets on a jacket. Other than that it is same in every way.
    All the best.....
    EV
  5. #5
    Senior Member
    Join Date
    Mar 2017
    Lincoln
    Posts
    401
    Only just came across this thread. I have the Orivesi jacket - a quick look on line confirms it is not a Paijanne although I could only find that jacket on a Polish website. It is also called the Roughroad.
    The overall finish is great; typical Rukka quality. After a long ride in the rain the outer layer does get very wet and takes a while to dry out - this is true of all jackets with a removable waterproof liner. I've stayed perfectly dry and the Outlast does a good job of regulating temperature. That said, with the liner in it is a very warm jacket for the summer months. When I wen to Austria I had a couple of rides in the low thirties. With all the vents open and the side vents undone, along with the cuffs fully open to allow some airflow up the arms and around the wrists, and unzipped a bit at the neck I was very warm but not unbearable so. That said, I run a bit hot anyway, being a little chunkier than I once was. I haven't yet used the neck warmer but that zips on in anger, but it was comfortable when fitted and wearing a helmet. The neoprene neckline on the main jacket also seals well. The one outside waterproof pocket is useful for the key fob (I ride a keyless GS) and of course there are waterproof internal pockets in the liner. The fit is generous and I find it very comfortable to ride in. The straps to tighten the arms are a bit superfluous for me, but if you have thin arms they might be useful. The waist adjustment helps to get a snug fit as well. The cuffs have a wide range of adjustment so there is no problem if you wear you gloves in or out. One issue I did find is that the main zip has a shallow fit at the bottom, and if you're not careful and also forget to use the press stud tab to close up the zip can come undone from the bottom; not good at 80+ on the autobahn! I always take car now to ensure the zip is properly fastened. The Jacket and liner both have zips for attaching to trousers and these also work with Halvarssons trousers so my Prince trousers are not redundant. Let me know if there is anything else you'd like to know Bazman.
  6. #6
    Join Date
    Aug 2015
    Annan,Scotland
    Posts
    242
    Thanks Guys, appreciate that, could get a suit for a very good price, but after a lot more looking into i'll probably be heading towards the armaxis.
  7. #7
    Join Date
    Mar 2016
    Hertfordshire
    Posts
    1,400
    Quote Originally Posted by bazman View Post
    I had armaxis. It has a cut that does not suit Adventure riders. I.e. Sleeves veer way to short for me. Navigator works nicely.
    All the best.....
    EV
  8. #8
    Join Date
    Aug 2015
    Annan,Scotland
    Posts
    242
    Quote Originally Posted by EVskij View Post
    Thanks EVskij, not good then, I also ride a fjr1300 blood bike, hence the need for a good bit of kit. Navigator looks promising also. Tries the Armaxion on last week but shop never had any other styles.
  9. #9
    Join Date
    Mar 2012
    Fife, Scotland
    Posts
    329
    Look into Dane gear, bazman. I'm 99.9% likely to get a pair of Lyngby trousers to replace my leaky Klim Latitude's, once Gore have refunded me.
    D.
  10. #10
    Join Date
    Aug 2015
    Annan,Scotland
    Posts
    242
    Quote Originally Posted by deksawyer View Post
    D.
    They're also on my radar cheers, too many to choose from nowadays!!
    My old hein gerike cruise gortex may get resurrected as a short term fix, the new hein gerike gear is not as good imo since they've went with layers ( sheltex).
  11. #11
    Join Date
    Oct 2016
    Under your bed
    Posts
    216
    Be careful with the Navigatorr on the GS
    The cut isn’t their Adventure style it’s suited mostly to road.
    There’s a huge gap on the joining zip and the aero on the GS causes a nasty draft even with winglets.
    Fuck knows why they leave such a massive gap - it’s hip bone to hip bone!
    The Outlast makes it even worse.
    I’ve resorted to using a Decathlon down instead at lower temps just like their latest top line suit. (The one that’s been on their site for over a year but Tranam have only just decided to bring in FFs!)
    Also watch out for leg length and size with your boots as they are very slim and for some reason they have decided to have the adjuster fold OVER they waterproof zip instead of being separated like on the sleeves.
  12. #12
    Join Date
    Aug 2015
    Annan,Scotland
    Posts
    242
    Quote Originally Posted by HammyUK View Post
    Thanks , bloody minefield !! Just put my old goretex hein gerike into wash with Nikwax reproofer, and see how waterproof it really is
  13. #13
    Join Date
    Mar 2012
    Fife, Scotland
    Posts
    329
    Just bought the Lyngby trousers bazman, so if they get here before you buy something, I'll let you know what I think.
    Bought them from Get Geared, as they price matched Sports Bike Shop, and they have easier returns via the Post Office - SBS use a UPS drop off point I think it is which is less handy for me...
    cheers
    D.
  14. #14
    Join Date
    Mar 2012
    Fife, Scotland
    Posts
    329
    Also, if your old HG suit is leaking, Gore might reward you with a replacement - after all Gore-tex is guaranteed to keep you dry, for the lifetime of the product. They've been brilliant with my Klim warranty claim. Just as well as Klim apparently never received the web form I filled in to start the warranty claim in the first place.
    Gore have been brilliant (Sabina handled my case).
    Worth a try.
    D.
  15. #15
    Join Date
    Aug 2015
    Annan,Scotland
    Posts
    242
    Worth a try.
    D.
    Excellent news D, never even thought of Gore lifetime warranty, thinking back when I was in France a couple years back it failed , but could have been due to my ineptitude with fastners and zips after toll booths ..
  16. #16
    Join Date
    Mar 2005
    Chichester
    Posts
    384
    Hi I have the Orvesi jacket not trousers as i could not get in short leg, xpilot is spot on. good jacket, good pockets for summer riding on a tour. inner works well.
    but yes zip is annoying not as good as you would expect on an expensive jacket. quite a big jacket so flaps a bit at high speeds.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
