Page 1 of 2 12 LastLast
Results 1 to 16 of 29
Thread: Cleaning Goretex
  1. #1
    Join Date
    Feb 2017
    The Hague, Holland
    Posts
    271
    Cleaning Goretex
    tips wanted on washing Rukka Goretex suit.
    I was told, put it in the washing machine with a mild detergent, drip dry and then into the tumble dryer for 15 mins to "reset" the waterproofing. Rukka website says about the same but recommends their own cleaning stuff
    Is this right?
  2. #2
    Deadhead Member Click here to find out how to Subscribe
    Join Date
    Feb 2005
    Nottingham England
    Posts
    26,951
    Yes.
    Andres
    Quote Originally Posted by Charles Martel View Post
    One of the five imbeciles of the vainglorious big swinging dick types of the Harley section
  3. #3
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,606
    Quote Originally Posted by Outtomunch View Post
    Yes.
    Andres
    Outtomunch doesnt post any crap ...its always considered and true.
  4. #4
    Join Date
    Sep 2009
    Cork
    Posts
    356
    Make sure the washing machine is free from any build-up of conditioners and softeners first.
    Boil wash empty helps.
  5. #5
    Join Date
    Oct 2016
    somewhere in time or Musselburgh
    Posts
    1,664
    Do a cold wash of towels with no detergent etc first, this gets rid of any fabric conditioner which you don't want near any goretex fabrics.
    I use nik wax cleaner, on all my rukka and hein gericke textiles. Light scrubbing with a nail brush with neat fluid on really dirty bits then a 30°c wash and then drip dry on the cloths line. I've never used the tumble drier bit, (mainly as I'm a tight fisted Scotsman) and haven't had any issues.
  6. #6
    Arse Click here to find out how to Subscribe
    Join Date
    Apr 2010
    Terra Firma
    Posts
    4,948
    Buy some washing machine cleaner and clean the tray before you start the process of cleaning the washing machine. Then use it to wash the Goretex. Any detergent or softener residue will affect the Goretex function over time. Been using Nikwax for years.
  7. #7
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,606
    Ride bike to ford.
    Ride bike into ford.
    Fall off.
    Roll around.
    Job done.
  8. #8
    Join Date
    Oct 2016
    Bedfordshire, England
    Posts
    660
    How about a 1000 mile ride back from Italy in the pissing rain, often torrential - all our gear, even the bike, was clean when we got back to Blighty, not a dead fly in sight. A few leaks on SWMBOs jacket though, which went back to Dianese/Goretex for repair (faulty panel with insufficient seam allowance).
    Contamination from fabric conditioner is a real concern though IMHO, so we usually wash the gear in the bath, with a specialist wash from Cotswold, then maybe tumble dry.
  9. #9
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,403
    Remove all of the armour , make sure that your passport isn't in the bottom of the inside pocket , wash as per instructions using the correct Nik Wax or similar cleaner and then reproof the outside with a goretex spray .
  10. #10
    Join Date
    May 2006
    Southampton
    Posts
    1,575
    Definitely don't use detergent mild or otherwise, soap is what you use. Put the washing machine through a cycle empty to get rid of any detergent from previous uses, really don't want to risk detergent ruining the goretex.
  11. #11
    rebircsbuS Click here to find out how to Subscribe
    Join Date
    Dec 2006
    The Home of Ferodo
    Posts
    2,365
    Lux soap flakes or whatever they are called nowadays.
  12. #12
    Join Date
    Feb 2017
    The Hague, Holland
    Posts
    271
    thanks all...its the tumble dry bit I am not so sure about....Rukka don't recommend so I wont
  13. #13
    Join Date
    Jun 2006
    Islandmagee, Co Antrim NI
    Posts
    9,358
    Quote Originally Posted by grantmac View Post
    As long as it is a "Low" heat it should be fine I think that they worry that folks will start a tumble and forget to turn it off after 15 mins or that it should be a Low heat etc etc
    Oh Great and Wise Deity, Grant me the serenity to accept the things I cannot change,
    Courage to change the things I can! And the wisdom to know the difference!
  14. #14
    Join Date
    Feb 2005
    Nottingham England
    Posts
    26,951
    Tumble drying is the most important part (for jackets with Gortex under the jacket main material - for Gore laminate I'm not sure?)
    There is a water repellent coating on the outer jacket (which needs reapplying every few washes). When it's working properly it causes the water to bead on the jacket surface rather than soak through and thus helps the Gortex do it's job. This needs 're-activating' after a wash whether you've reapplied it or just reactivating an existing coating. Heat is what re-activates it.
    Any way, as with all things OP, don't take anybody's word for it on here, look at the Gortex web site for some very good info on how to look after the various types of Gortex construction.
    Andres
  15. #15
    Join Date
    Oct 2008
    Blyth Notts
    Posts
    1,364
    Hi
    I Sell this I use it on my two Rukka Armas jackets and Cosmic pants all the time PLUS its TANAM AND RUKKA Approved...
    http://www.ebay.co.uk/itm/Storm-Wash...e=STRK:MESE:IT
    Cheers Big D
    Is this right?
  16. #16
    Join Date
    Oct 2008
    Blyth Notts
    Posts
    1,364
    Yes Rukka needs to be tumbled a sits a HEAT cure process and the other important factor is remove all D30 or amour then turn garment inside out before setting off the wash cycle.
    Andres
Posting Permissions
  • You may not post replies
  • You may not edit your posts
