Page 2 of 2 FirstFirst 12
Results 17 to 29 of 29
Thread: Cleaning Goretex
  1. #17
    Join Date
    Nov 2013
    Sanquhar. Scotland
    Posts
    90
    1) Clean any detergent from washing machine
    2) Wash with Nikwax Tech Wash at 30Deg
    3) Then wash with Nikwax TX Direct Wash in. Again at 30Deg
    4) slow spin
    5) Dry on washing line.(or Pulley - I don't have a dryer:-) Once feeling dryish, turn it outside in & hang for further time till dry inside & out.
    Job done
  2. #18
    Join Date
    Oct 2008
    Blyth Notts
    Posts
    1,364
    This is OK for washing but heat is needed to re proof thats why tumble drying is needed
    Quote Originally Posted by Marjie View Post
    4) slow spin
    Job done
  3. #19
    Join Date
    Aug 2014
    Cotswolds
    Posts
    500
    Sorry if this has been done before, but what's the need to reproof Gortex for?? Surely the point of Gortex is that it's a fabric designed to prevent water entering and shouldn't need to rely on an external coating of waterproofing. Surely any coating would prevent breathability. Confused.
    As an aside I use a Gortex lightweight viz yellow cycle jacket (Gore) and a pair of Sprayway Gortex zip up the leg trousers and when it rains hard (50% of my journey from Geneva) they stop the road crap from covering and expensive set of Rukka. They pack to nothing, weigh nothing. Both are now filthy dirty hence why I'm looking at this thread. Wearing these over the suit meant I could leave all my jacket and trouser vents open underneath. After each day the Rukka gear was bone dry (unlike previous boil-in-the-bag 'solutions') and perfectly clean. £150 for jacket and troos, also bone dry inside despite horrendous rain at times. I don't mind binning £150 every couple of years rather than a very expensive suit. My take on things obviously and won't suit some on here, but working well for me.
  4. #20
    As I understand it. The holes in Gortex are so small this is why rain doesn't get through. But vapour IE perstpration does get through as its smaller droplets than cold water.
    The tumble dry process helps pull the weave of the Gortex back together nice and tight so as to work. You don't need to add anything to waterproof it.
    Cheers.
  5. #21
    Join Date
    Jan 2002
    Cheltenham
    Posts
    6,682
    I use Nikwax at the moment as Tesco were selling litre bottles of both green soapy stuff and the bluey purple waterproofer stuff.
    I just lob the garment in the washing machine with a dose of the green in the wash and a dose of the blue in the fabric conditioner section - seems to work. Garment clean, fresh smelling and the outer fabric beads water.
    When my green is depleted I will go full cheapskate and use the only equivalent of Lux flakes I could find, Wilko Liquid Soap Flakes.
    This space deliberately left blank as the author writes too much pretentious bollocks as it is.
  6. #22
    Out of interest, this is from the Rukka website:
    for Rukka jackets and trousers
    See the individual care instructions at each product.
    Remove protectors before washing.
    Machine wash inside out on fine wash programme at 30-40°C with normal fine washing powder without soft rinse agent. Rinse thoroughly. Put only one product at a time in the machine.
    Dry clean according to care instructions
    Iron at low temperature (no. 1 setting). Not the reflecting areas
    Tumble dry at low temperature (max 55°C) one item at a time
    Note!
    AirPower products (Cordura AFT material) - No tumble dry
  7. #23
    Join Date
    Jul 2016
    Devon
    Posts
    27
    Maybe an obvious question, but what if you have no tumble dryer or know anyone that does?
  8. #24
    Join Date
    Dec 2005
    Hatfield,Herts
    Posts
    2,357
    Quote Originally Posted by Dirty Ming View Post
    Launderette or just air dry on a nice day
    Please support London's Air Ambulance
    http://londonsairambulance.co.uk
  9. #25
    Join Date
    Jun 2012
    Romford, Essex
    Posts
    251
    Try your nearest launderette. They have lots of washing machines and a tumble drier.
  10. #26
    Join Date
    Jan 2002
    Cheltenham
    Posts
    6,682
    You DGAF and revel in all that electricity not used.
  11. #27
    Join Date
    Aug 2005
    Wensleydale, North Yorkshire
    Posts
    301
    Use an Iron on low heat it does the same thing, it's only to reactivate the dwp on the outer fabric layer so it doesnt get saturated with water which stops goretex working properly.
  12. #28
    Join Date
    Jan 2002
    Cheltenham
    Posts
    6,682
    Quote Originally Posted by AA388 View Post
    a Tosser is more likely to have a hair dryer accessible
  13. #29
    Join Date
    May 2007
    Glasgow, Scotland
    Posts
    541
    No detergent. It will degrade the DWR. Use Nikwax Tech Wash and reproof with TX Direct.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
