Results 1 to 5 of 5
Thread: Portable motion detector
  1. #1
    Join Date
    Jul 2004
    Nantwich, Cheshire, England, EU
    Posts
    1,060
    My R1150GSA does not have an alarm so, either use a chain or disc lock. Most of the time parked up on the side stand.
    I would like to consider buying a small motion detector alarm that can be recharged through the bikes external socket outlet. And when using it, switch it on and attach via Velcro somewhere on the bike while away. For example, under the top box, under seat, under beak or under engine bash plate.
    If someone tries to lift it vertical, it goes off.
    Is something like that available?
    Sent from Steve's fancy iPad using Tapatalk
    A GOAL is an end toward which some specific effort is directed!
    Go forth and prosper!
  2. #2
    Join Date
    Jul 2009
    Aberdeen
    Posts
    10,996
    There are various locks with a motion sensitive alarm...
    https://www.amazon.co.uk/s/ref=nb_sb...ive+bike+alarm
    you can also get these.......would do the trick.
    http://www.ebay.co.uk/itm/like/38163...6936013&crdt=0
  3. #3
    Join Date
    Aug 2007
    UK/France
    Posts
    15,173
    Get a Harley, they already have them as standard.
    There can only be 11 and I'm one.
    My pics
  4. #4
    Join Date
    Jul 2004
    Posts
    1,060
    Quote Originally Posted by stolzy View Post
    Got a 2010 FLHTCU with one fitted, buried in the garage.
  5. #5
    Join Date
    Jul 2004
    Posts
    1,060
    Found this simple and cheap device. Charge at home.
    Park up, switch on and stick somewhere discreet on the bike.
    ***On second thought it is infrared and may not work if hidden***
Posting Permissions
  • You may not post replies
  • You may not edit your posts
