Africa Twin farkles list
Got the matching adjustable rear brake lever to go with the gear lever, same nice quality. I’ve also removed the Kawell DRL from underneath the headlamps and got these DRL’s which will go inside the fairing cowl. Should be wired and properly mounted tonight. :thumb2
I like those DRL’s, can I ask where you got them??
Finally got them wired in....what do you think ?
ACD skid/bash plate fitted today. 20 minute job, nice and easy. :thumb2
£150 direct from Spain...excellent value IMO. :beerjug:
Samco hoses.....full kit except for the bugger that runs under the battery box and required me to strip off a load of stuff that I’d just fitted back on after the valve check. Sod that, it can wait until the next time the bike’s in bits !!
Samco hoses.....full kit except for the bugger that runs under the battery box !!
I fitted the full kit and only had to remove the black trim, the hose by the battery box is doable without stripping anything off, i used a blob of silicon grease and it slipped on the ends with ease.
What crash Bobbins do you have on your bike? Davy
They’re GSG bungs made in Germany. Only reason I fitted them was due to the Arrow pipe, I couldn’t fit anyone’s engine bars as the O2 sensor is unfortunately coving an important bolt (although this flaw might have been rectified on later production pipes).
I’ve obviously been a good boy this year and Santa has left me a nice little farkle of an Atlas throttle lock.....:aidan
