The first time I took the drive shaft out on my 1100, I degreased it and used a moly dryslide lube (used to use it on gun slides back in the day) - basically minute flakes of molybdenum in a solvent carrier which evaporates). Two or three coats of this burnished between coats and afterwards and then a coat of Honda Moly 60.
30k miles later I took the gearbox off to get it rebuilt and the drive shaft splines were perfect. Almost no evidence of grease left on the splines (just a rim of sticky residue behind them) but the splines still had the dark grey colour from the dryslide / moly residue from the 60% moly content paste. For the U/J's, I used CV joint grease which also has a high moly content (although it's a lot thinner and more like a traditional grease than the paste like Moly 60). I'd imagine that CV joint grease would probably do fine for the splines but might not last as long.
If I ever take the drive shaft out of my 1200, I'll do the same with dryslide and Moly 60.
I bought my moly 60 from a reputable eBay seller (a bike shop from memory)
