After getting advice on here in relation to wiring a FIAMM Miniblaster through a relay I did so...
I have 2 of them because I thought the first was faulty.
When I press the horn button the relay clicks and I get 12v at the horn. I have used the earth wire which was originally at the horn and also tried running a new one just in case.
I have changed the feed from the battery to 27a wire in case it’s too thin.
Horn doesn’t work and the fuse blows after a few goes or holding the button for more than 2 seconds. tried 10a fuses.
Both Horns works fine when I try directly from the battery... and as I said, getting 12v at the horn no problem...
One make no noise at all and one seems to be trying to do something... kind of a quick popping sound.
What am I missing???
