In the process of removing the Garmin wiring for the Zumo 550 the powered mount went in to this plug near the headlight.
Could someone confirm what it is? The replacement I have has the usual fused power connectors for the battery.
I’ve got to remove the rest of the Autocom and Autocom Bluetooth wiring that descends in to a snakes wedding beneath the fuel tank, but a simple power solution using that plug would be very useful and get the new powered mount up and running (different Zumo so different power plug, thanks Garmin!)
Is it a Canbus plug if so is it better to put the Satnav power through this and what’s the best way to get the 2 wires that would go to the battery in to the plug. The current plug has very narrow wires?
It’s a 2009 GS.
Thanks in advance.
It’s a 2009 GS.
Thanks in advance.
