Looks good Mark, another great product mate.
Fanks Nuts ride safe babes
Thanks again for the toolbox Mark. This also looks interesting. Will it fit a 2006 GS with GSA pannier frame?
Hi Mark,
I am tempted. Is it waterproof or rather water resistant. I there a seal on the door or can one be fitted. I know I can put things in poly bags but they rub through in no time and old rags soak up water.
Cheers.
Hi Mark,
Cheers.
Looks really cool, we do not have plates that size here in Germany, but can see its uses, puncture repair and aspirins for the morning after.
218 wide x 170 high x 56 deep - sorry, I should’ve posted that earlier doh - dimensions in mm’s of course and approx
Put my order in today, can’t wait
Hi Mark,
Did you consider having the hinge on the bottom? If so, what were your reasons for going for the side hinge?
Ian
Can this be mounted upside down so the door is hinged and opens to the left? silly question as I've just noticed the pre drilled holes only allow fitting in one direction.
Could you make this as opening to the left as it's easier to get to when the bike is on the side stand?
