Deleted account 200417001
I was in that area in May 16 and concur that the roads are superb. I wore out my PR4 rear but not quite like that!!
probably had correct pressures in yours, those worn ones clearly didnt.
... its Spain you ride fast searching for the next buzz , I dont look at the scenery , just the next corner.
Boxer , the CR3 has a flatter profile than the PR5 see below.
The rear is more like a front than a rear , way different from the CR. In the back ground you can see a Road tec rear ( okay used ) but profile is similar to the CR
And to add there is no way I could go lower without digging the pegs in , most roads in Spain as you know have such good camber as well .
I've read the opposite advice, that is to keep looking outside. Only possible in the daytime, but I think the theory is if your brain can see the horizon moving then that movement will agree with what the balance organs in your ears are saying, so brain is happy and stomach contents stay down. However if the messages from eyes and ears disagree, as when your visual frame of reference is the unmoving (relative to you) interior of the boat, but your ears say you are pitching about, then nausea results.
Then what's the point of going all that way when what you really need is a track? If you're doing that to your tyres on public roads, it's time to do the rest of the road users a favour and stop doing it.
I found I started scraping pegs once I fit the Roadtec 01, never happened with the PR4
No checked my pressures every morning , 2.5 and 2.9....
Do you use those pressures for 1-up/2-up/luggage etc.?
You could scrape the pegs already in 2013 with Mezeler Tourance Next.Pirelli Scorpion Trail 2 were even better lasting longer and quicker steering.Metzeler Roadtec 01 better in the rain.Continental Road Attack 3 very quick steering,stable,very predictable and super sticky.With a light mileage penalty compared to the Pirelli.Tried the PR5 on a friends R1200S yesterday.I.M.H.O. the Pilot Sport 2CT from 10 years ago felt better as in quicker steering and more grip.But I don't trust Michelins anyways because they don't give you warning.They stick and then let go without warning...Had my fair share of crashes on them.Only brand worse is Bridgestone.Too quick to wear out and dangerous when wet...my experience.
Can you post some photos to show us some of your experiences with different tyres, Stick was good enough to go out ride and show, please do the same.[/QUOT
Thanks , I have done different post on tyres , this one perhaps a little more as I had a good test bed ( for me ) to show for some a datum for others to work from.
I have tried many tyres and the PR5 is great , but as you can see when ridden hard over a short trip , wear fast.
Given the same ride but more conservative approach the tyres would have lasted longer , but stiil would have worn more than I would have expected.
The Conti TA2 for me is still a great tyre but the new generations of tyres now being developed will overcome the evolution in the current market of bike updates and I hope , we will have a tyre that gives a sporting edge without the need for wet weather design as for some trips are based on good weather and dry roads.
We may have a tyre choice to suit all soon.
Will give the Dunlop RS3 a go next as they seem a good option , lets see.
@Smogbob;tire pictures tell you nothing about how good or "fast" a tire is unless they are taken from racers who are running at the same day with same temperature conditions and lap times.
It is very easy to murder a tire in a short time and still are slow compared to a much smoother and faster guy who runs different lines,steers quicker,maybe even runs less lean angle but keeps his momentum and not hard on brakes or gas.Those tires will last much longer and look like they came from a slower rider...
Of course if you are a experienced track day rider and you run a GS with the available tires at a A-group pace they look murdered because these tires are not made for the temperatures they reach.They get hot,greasy and then can let go without warning because they are not made for that temperature window.Sticks tires got worn but they did not overheat otherwise they would have been blue because on the street even running fast you can't reach medium to fast track pace.
That is why it would be nice if BMW would bring a 17" wheel option to be able to run track appropriate rubber and have a slightly quicker steering bike !
Stick never give up...
If you like the Michelins more power to you.
I just think currently the CRA3 are the cat's meho...
What’s a CRA3?
