So not even true variable valve technology, just two ratios. I’m not that imprsssed, a tad disappointed even.
The engine will be Euro-4 / 5, and still run lean, so a way of adding a bit more fuel will probably still be desired.
I think gold wheels on modern bikes look bloody terrible!
Of course, there may be changes in the engine management designed to lock out Hilltop type mods!
Nothing will be mistimed as they can only slide over while the cam lobes are flat.Try a VW GTI and you will see it is totally seemless.Of course we will know for sure after the first test-rides.
As for added complexity I can only see the unit that chooses the low rpm/high rpm pin to choose the fat torque/high rpm power cam lobe !
As for the Ducati or Kawasaki single cam lobe systems or the mechanical system on the GSXR 1000 those systems doen't work as good as 2 cam lobes ground for either fat torque or high lift high hp applications as it only advances or retards the same cam profile.
And the Honda VTEC system on the VFR800 worked totally different with a hydraulic pin that went from 2 to 4 valve operation to lock in the rocker which neither gave good low rpm torque or high rpm hp and felt like the engine had hiccups around 6500 rpm.And was expensive to maintain come valve adjustment time...The BMW system has 2 cam lobes optimized for torque and power and probably changes around 5500 rpm looking at the cams and will be adjusted as the current one...maybe the intake cam can even stay and you can push the rockers sideways to change the little half ball bearing shims which would make it even easier.In a few days we will know for sure but I like what I see !
The alpha-Technik VV-L system was mechanically beautiful but probably too costly and complex for mass production and long mileage use and maintenance...
I actually find these threads amusing, most are screaming yeah baby more power faster, yet 99.9% of riders who buy a GS buy it because it is easy to ride comfortable on the older bones, and can go on the gravel if needed, it is very similar to the computer threads, new computer coming out more speed more power, must have,yet most only send email surf the net, and look at the odd video.......... I personally could not take my GS to its speed limit or cornering limit, so no more speed or power needed, and 2 up it pulls like a train, well impressed.
143 NM, baby.....YEAH....
.... yeah, more tyre wear, more final drive wear, more clutch wear.
In the real world, out riding with your mates, it wont be any faster than a 1200 GSA.
Your cornering speed brain won't change, the weight won't change, tyre grip won't change, you're riding ability wont change, nothing will change....
But you'll be paying for it anyway
Disagree. Two up and luggage my GSA was wanting. Despite Hilltop map and Akra the bike needed more. Especially when you brimmed the 30l tank! I know I'm right because I have zero issues with the more powerful 1290S. Imagine the new engine will attempt to address the deficit.
But that isn't about the bike, that's about the weight on the bike....
