fred_jb
I've been having a closer look at the picture of the new 1250 and have concluded that rather than just new cylinders/heads and exhaust, it is actually a completely new engine. If you compare the following pictures you can see that relative to the frame, which appears unchanged, the cylinder head is both higher and further forward than the current engine, and the oil level window looks to be in a slightly different position. If true this must mean that the new engine has different crankcases and a modified internal structure, which could have implications for weight distribution and handling. It also seems that the O2 sensors have moved or been removed.
