NicD
When I removed both front wheel bearings the right side spun almost as new. The left was utterly dead. Barely spins and feels like there are rocks in it.
Looking at seals there is clearly a design issue. Right hand seal covers both races, so packed with grease it will prevent ingress of water. Left seal has wider inner diameter to seat spacer that sits between left hand bearing and fork leg. This seal does not cover the inner race of the bearing, so water can get in and wash out the grease in the bearing, knackering it.
Going forward I will replace the left hand seal in a couple of years and ensure that the outisde face of inner race is covered in grease to keep water out. Definitely don't pressure wash that side of the axle.
