New to me K1200LT
foot flaps
yes I made them, very simple. some people use plastic cut from an oil bottle.
I had uneven idling which turned out to be two separate issues :
A split intake manifold rubber boot and a Fuel Injector O ring failure
After twenty years the rubber on the bike is just hard and brittle
Also changed out the fuel distribution hose
A friend has a Triumph Sprint ST, bought new in 2000 and well looked after. It's a lovely bike and mechanically has been very reliable for all sorts of riding, including a spell as a commuter into London. However, it has been rendered effectively worthless by all the rubber bits that have become brittle and split - air hoses, fuel hoses, fuel seals, connecting hoses... The price (even assuming the parts are still available) and time required to change everything make it a non-starter (in every sense).
Thankfully I have now changed out all of the old rubber parts which were all readily available so the bike should be good fo a fair few more years now ;-)
Did you also replace the brake hoses ?
I'm fettling a 1996 Pan European, and all of the moulded hoses with complex connx for the LBS are now EoL from Honda.
I'm discussing with Venhill the options for reproducing a full ST1100 ABS/LBS kit - 17 hoses.
Yes - if you read above you will see I replaced all of the brake lines with SS braided hoses (Goodridge) ;-)
You could also look at this guy's eBay shop for a possible brake line solution.
https://www.ebay.co.uk/str/LIGHTENUPGRADE
He has a good reputation over on the Pan European facebook group.
Over the winter the bike has had a new rear main seal , new clutch , all new gearbox seals , new clutch slave cylinder , new throttle cables and a few other bits and bobs
This weekend I upgraded the front end to the later style forks and lower bridge which has 0.5° more rake and 15mm more trail" from a 2005 model
This should help with low speed handling
Fitted a new ball joint and also put on a HyperPro progressive spring
Also fitted the later EVO brake calipers which I fully refurbished and a pair of discs with new bobbins and wave washers
Only issue was I ran out of SS Torx bolts so have to order some more so still got a few corroded caliper bolts to swap out :-(
Brakes feel really good with lots of stopping power and the ABS II works fine
Its all ready now for this years trip down to Spain
Nice bike had a test ride in about 1997 and was impressed at the same time had a ride on a C1!!, not so impressed. Read this and suddenly whilst reading about replacing rubber bits I suddenly realised that this
was a l o n g time ago! where does it all go?. Best of luck with a good machine.
