commandoallan
Hey all,
Could do with a little advice.
I have changed the fuel pump on my R1200GSA (2008), it starts up and runs fine but then the bike cuts out after 30 seconds or so in idle, it has also cut out several times when going along the road. When the GS911 was connected it showed multiple instances of the new fuel pump tripping the electronic fuse.
Voltage when tripped seems to be around 6V and up. Has anyone got any idea what the internal electronic fuse is set at and if the previously connected "Ground???" wire on the old pump is used for anything? The new pump did not have a ground wire or a connector for this existing wire.
My readout from the GS is attached.
Many thanks.
Many thanks.
