Front Brake Discs
Hoff
Denmead, Hants
Bike is a 2017 F700GS
The bike has floating front brake discs and I understand the reasoning why they are used and fitted.
My question is when you grip the disc and try to rotate it how much movement is acceptable?
I appreciate there will be some but how much?
TIA
Paul
Just popped out to the garage to check on mine (2012 F700GS, 20k). I'd guess about 2mm movement.
(Also checked on the K1600 - 2016, 10k. About the same.)
Just checked, movement on mine is approx 1.5mm so I will call that good.
