Thanks for the suggestion, well intended I am sure, but I do know exactly how to use the quickshifter, it's just that I prefer not to use it. While I don't want to start a big debate on this, the reason I don't use it is that I feel that unlike DCT type gearboxes, quickshifters are a bit of a bodge solution and put additional strain on the transmission, especially on upshifts. On downshifts the engine gets blipped which assists with matching road speed to engine rpm - but you can't do a negative blip to reduce engine speed when changing up a gear!
When you change up a gear the engine revs need to drop to match the current road speed to the new ratio. When you use the clutch to do this you disconnect the engine from the transmission and rear wheel, and allow the revs to fall appropriately before reconnecting them. Do this right and you get a smooth change with no undue strain on the transmission, and even any slight mismatch between engine revs and road speed is smoothed out by a little clutch slip as the clutch reengages.
In contrast, when using a quickshifter there is no disconnection, so the rear wheel, via the transmission, instead of just matching the speed of the gearbox internals to the new ratio, also has to forcibly, and almost instantaneously, slow down the engine with all of its all heavy rotating masses as the new gear engages. The only help it gets to reduce the extra strain this puts on the transmission is that the quickshifter cuts the ignition for a few milliseconds, so that at least the engine is momentarily unpowered, though to slow it down the inertia of all that rotating and moving metal still has to be overcome.
Regarding the odd popping noise, I am not worried by this, more just interested to find out if the ShiftCam operation might be audible, though I agree with all the roadtesters that you cannot feel it happening through the engine response. If it is happening on each upshift during hard acceleration then you would think the system would just keep the fast cam engaged to avoid excessive cycling between the slow and fast cams. This would be similar to a technique called hysteresis which is commonly used in electronics, whereby to avoid excessive cycling between two states you avoid the switch happening at the same point in both directions.
