Der Lustenauer said:
...With MapSource and CS7 I make a little route there where I want to explore. These are rarely longer than 20-30 km and run parallel to the main roads but have in-between other roads leading to the main one. Easy done in CS7. 2 Clicks normally (Start, End).
Considerable more hassle with CN8 as it tries to get me away from there to the main road, working against me.
Hello Egon:
Ah-ha - the sentence I have highlighted in blue is the key to comprehending everything.
The cartography itself (CN or CS 7 vs. CN 8) has nothing - nothing at all - to do with routing. All the cartography consists of is a database of vectors that represent the roads - this we see on the screen of the GPSR or the computer - and a set of 'street attributes' for every road that detail the nature of the road - its size, width, speed limits, number of stop signs, type of surface, and so forth. The cartography has no intelligence at all, so far as routing is concerned.
The question of which roads are chosen when a user asks either the GPSR or the MapSource application to automatically construct a route is determined by the 'routing preferences' settings in the MapSource application, or the 'advanced avoidance' settings in the GPSR.
So, if you were able to get the kind of results you wanted from version 7 of the cartography, you should be able to get the exact same kind of results from version 8 or version 9, assuming that the roads you are interested in were not deleted from the cartographic database - an unlikely possibility.
To solve your problem, go have a very close look at how you have set your routing preferences up. Keep in mind that you have more choices available to you, so far as preferences go, in the newer versions of MapSource and with the newer software releases for the GPSR. It is quite possible that your problem might be as simple as having the 'avoid unpaved roads' box checked, or having routing preferences set to prefer major roads. It's difficult to set preferences up to 'prefer passes' because passes are usually neither shorter nor faster than tunnels. But - what you might want to do is take advantage of all the new technology in MapSource and the GPSR to work in a way that might not be immediately apparent:
Just go to the 'Avoidances' section of the GPSR or MapSource, and mark off the tunnel (the primary route that 99.5% of the drivers take) as a 'custom avoid' area - the same way people mark off ghettos, etc. in major urban areas as custom avoids. Now, the GPSR will know that it cannot use that tunnel no matter what - so, if you set your preferences to 'shortest route', the pass will probably be the shortest way from A to B if the tunnel is disqualified, and a route through the pass will be presented to you as the first possibility. The same rationale goes for highways... if you told the GPSR you wanted to go from London to Edinburgh, but you disqualified the A1 / M1 by listing it as a 'custom avoid' - you would get routed along the secondary roads all the way.
Michael
