Exhaust Thread Repair
Garry H
Midlands
I Have been thinking about a good way to repair stripped exhaust threads for a while now...Crap day so i have been playing about in the workshop....I have been thinking about this for a while and came up with this way :thumb
This is the hard bit screw cutting a new thread once you have machined down the knackered thread
You now have a new thread thats too small .. :eek:
So i could make a new nut to match the undersize thread or if you want to use a standard nut a collar to adapt it back to the correct size...Being made out of brass it won't pick up again :thumb
Screw the new collar on...No welding or shrink fit
And there you have it ...Good as new :thumb
Firkin Gorgeous, well done!
Someone will be along in a minute to ask what you did to stop the threaded bush unscrewing........
This is the same method that my local engineering shop use - But they also pin the brass sleeve, as they found they will come undone, even in everyday use.
I won't say how much they charge to do the work :eek: :eek: £££££
I would put a pin in to stop it turning/comming undone...but because this is a scrap head i used just to prove i could do it i didn't bother...I could do this for people if they want...But it is a fair bit of work so would not be cheap...but it would be a excellent repair :thumb
Aye that's how mine was repaired, think 40 something squid via Motobins, but 2 pins, one of which is not such a great good as it's come through the alloy a bit. still, does job. Now I'm sure there's a market for you Garry should you get bored :rolleyes:
Thats a great bit of turning and I can understand the amount of time it takes to set up and machine.
:thumb
very nice piece of work. I'd be well chuffed to see that work done with my own hands. :thumb
