I second Mike's posting about the mechanic. In fact I think he did his back in putting it inside his garage, or whatever.
I myself have a Chinese made Hydraulic one.
http://www.mandp.co.uk/netalogue/shop/buyside/buyside.asp?catref=&profile=0
If you go to that link it's the exact model that I have only in a UK store.
One day a Chinese manufactured hoist came onto the market for $399.00 Australian about 133 pounds sterling. It was really designed for the lightish market segment but is designed to lift 399 Kg or 880 Lbs in total. With about $40 spent on some frame strengthening in the form of welding some 3/4" angle iron and manufacturing my own ramp and some cans of red paint I was in clover.
I can drop the rear end off which makes pulling off the rear or front wheel a doddle and as far as dropping off the bevel drive and shaft for servicing, it's dreamland.
It has two levels of height, 520mm and 700mm and the centre stand sits on the platform at that height which means that I can have the cylinder heads at chest height for valve clearance checking etc, etc, or drop it to have the top of the tank at chest height.
My lift comes apart and is slid under my work bench for storage, that is, after I added some 75mm wooden chocks to the base of the workbench legs. I now don't get a sore back from bending and I also know that my workbench height should be 1,000mm and not 900mm in height, as previous.
Mick.
