locktide the screwws that connect the + and - from the battery.
check the bolts from the subframe.
That's what the dealer said.
I would ducktape the fuelcap cover tot the seat, thats the part that lies somewhere in the woods in holland....
I also ducktape the air intake on the inside of the right side panel, so no watter or dirt can splash against the side panel en drips in the air intake.
The gashandle throttle cable is from out the box very loose, ik could turn a lot before the engine come alive.
so i thightent it up a bit.
And check youre static sag out of the box this was 50 mm, and the suspension was not as it says in the manual.
