Page 1 of 2 12 LastLast
Results 1 to 16 of 23
Thread: Adjusting paralever bearings
  1. #1
    Senior Member
    Join Date
    Jun 2009
    Cluj, Romania
    Posts
    499
    Exclamation Adjusting paralever bearings
    Hi all,
    My '95 1100GS has some rear wheel play; if I press the rear brake, the play is still there, so that means it's not the big bearing, and all I have to do is adjust the shaft bearings, right?
    Just want you to correct me if some of the below steps are not OK...
    • Remove rear wheel.
    • Loosen strut at rear wheel drive (1).
    • Release clamping strap (2).
    • Heat free bearing journal (3) to max. 120 °C/loosen; heat fixed bearing journal (4) to max.120 °C/loosen.
    • Clean 3 and 4 of Loctite
    • Grease the bearings
    • Screw in fixed bearing journal (3) using Loctite.
    • Apply Loctite to the entire length of the thread on free bearing pin (4), and screw it in.
    • Tighten fixed bearing of swinging arm. (3)
    • Torque Fixed bearing journal (3) to 150 Nm
    • Tighten Free bearing journal to 7 Nm (4)
    • Tighten Locknut to 105 Nm (3)
    Is this all? Am I missing something?
    Thanks!
  2. #2
    Senior Member
    Join Date
    Jun 2009
    Cluj, Romania
    Posts
    499
    Wile I am in there, I should also replace the inner race roller bearing, right? bike has now 104000 km.
  3. #3
    Join Date
    May 2005
    cumbria, the real north west
    Posts
    3,774
    yes, to adjust them, just heat the inner pivot, loosen the locknut, then using the 12mm allen wrench, move it clockwise a degree at a time, do this all with the wheel still on, check play by grasping the wheel, when play gone, do up locknut, recheck the wheel for play in 500 miles, if its back, then replace bearings
  4. #4
    What a waste. Click here to find out how to Subscribe
    Join Date
    Oct 2003
    S/W London.
    Posts
    43,640
    Quote Originally Posted by dancata View Post
    if your just adjusting the bearing there is no need to remove anything, not even the wheel - use an extension bar between the spokes.
    All your BMW servicing needs at the .gsshop.biz, including 1200 models
    Recommended as an "excellent independant" in Ride magazine 2009.
  5. #5
    Senior Member
    Join Date
    Jun 2009
    Cluj, Romania
    Posts
    499
    Quote Originally Posted by ianboydsnr View Post
    So no need to heat/unscrew free bearing pin (4)? Just heat the inner pivot (3), get it out, clean it and put it back in while adjusting?
    Q: when I remove the inner pivot, does it get back inside easily?
  6. #6
    Member
    Join Date
    Dec 2007
    Bucharest, Romania
    Posts
    64
    Hi all,
    I'm no expert but if the symptoms are as described above we are talking about
    exactly the big FD bearing don't we? The worn paralever bearings should manifest as a play which will be gone when the rear brake is applied, or am I wrong?
  7. #7
    Join Date
    May 2005
    Posts
    3,774
    no need to unscrew, clean or remove, your just tightening it slightly to remove play
  8. #8
    Join Date
    May 2005
    Posts
    3,774
    Quote Originally Posted by Superhypo View Post
    Your wrong
  9. #9
    Senior Member
    Join Date
    Jun 2009
    Cluj, Romania
    Posts
    499
    It's the bearings i need to adjust, cause with or without the rear brake pressed, the wheel moves together with the final drive, so the big bearing inside the FD is ok, even at 100k km.
    Also, I thought I needed to heat the adjusting screw because of the loctite on it... Won't the adjusting screws threads get destroyed if screwing or unscrewing it without previous heating?
    Thanks.
  10. #10
    Haud via quoque scabrosus Click here to find out how to Subscribe
    Join Date
    Feb 2002
    Stockport
    Posts
    2,530
    Note the fixed bearing is (4) and free is (3). You start getting them mixed up half way through
    '06 HP2 E...................2006 - 2014
    '02 R1150 GS Adv........2004 - 2006
    '01 F650 GS Dakar.......2001 - 2004
    '91 R100 GS...............1995 - 1999
    '83 R80 G/S...............1986 - 1993
    '81 R80 G/S...............1982 - 1985
  11. #11
    Don't use loctite when you replace everything, it's not needed and the threads won't come undone.
    It's also makes life easier if you need to adjust the bearings whilst on a trip.
    Don't worry too much about torqueing up when you adjust, just take up the free play and tighten the lock nut hard then check again.
    If it needs adjusting again within a couple of thousand miles then the bearing will almost certainly need changing.
  12. #12
    Quote Originally Posted by Timolgra View Post
    Because the bearing will not be worn evenly (it only rocks back and forth).
  13. #13
    Join Date
    Oct 2003
    S/W London.
    Posts
    43,640
    Spot on - people can get a bit anal over the paralever bearings and adjustments.
  14. #14
    Senior Member
    Join Date
    Jun 2009
    Cluj, Romania
    Posts
    499
    My only fear is that i will destroy the threads while adjusting, without heating the screw, but if you say it's ok, I will go ahead.
  15. #15
    Join Date
    May 2005
    Posts
    3,774
    You will need to heat the screw, if it has threadlock on
  16. #16
    Join Date
    Jul 2002
    Cotswolds or Chilterns
    Posts
    1,715
    Click here to find out how to remove these ads
    Yeah what he said – I’ve stripped the threads out of swing arm before by not using heat. Had to buy a whole new swing arm. Whilst I appreciate that it may be possible to adjust paralever pins with the rear wheel in situ, I think it would make sense to remove and heat – just in case.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
