Results 1 to 16 of 16
Thread: Gearbox Overhaulers
  1. #1
    Senior Member
    Join Date
    Jan 2007
    Cologne,Germany
    Posts
    410
    Gearbox Overhaulers
    I want to get my g/box overhauled this winter and get the short 1st gear/long 5th gear mod done at the same time. Can anyone recommend a good source? The local companies are a bit expensive but I don't have the overseas postage problem, UK overhaulers are cheaper. Eitherway I'd prefer to use a Tosser pre-approved source. I'd do it myself but I have no time available. Does having the taller 5th gear make a big difference?
  2. #2
    Senior Member
    Join Date
    Apr 2010
    Whitchurch, Hampshire
    Posts
    526
    Quote Originally Posted by Sylvester View Post
    I saw this quote by Steve Sciminger who builds boxer engines to be good enough to go in planes ...
    Vapour clean gear box case £30.00 plus vat
    Bearing kit £62.50 plus vat
    Selector kit £8.50 plus vat
    Gasket and seal kit £20.00 plus vat
    High 5th £99.00 plus vat
    Labour to rebuild is £125 plus vat
  3. #3
    Join Date
    Apr 2006
    Bollox yer nosey gits
    Posts
    11,393
    IMHO
    I'd rather try and persuade Rob Farmer to rebuild it for you...
    He's done one for me and it's silky smooth now
  4. #4
    I should change this Click here to find out how to Subscribe
    Join Date
    May 2003
    and this as well...
    Posts
    17,813
    Quote Originally Posted by Proff View Post
    IMHO
    But be aware there is a queue...
    Quote Originally Posted by Ronno View Post
    Then I remembered. He doesn't ride a GS. Therefore he aint at the sharp end of Dudeness...
    Quote Originally Posted by Wapping View Post
    'Where there's offence, there's brass'
  5. #5
    Trustworthy Scouser AND
    Join Date
    Jan 2002
    Toxteth scouser, made good ..now hiding on the Wirral
    Posts
    8,442
    Leave poor old Rob alone...he has his own projects these days !!
    Politics is the art of looking for trouble, finding it everywhere, diagnosing it incorrectly and applying the wrong remedies !
  6. #6
    Member
    Join Date
    Nov 2008
    Singapore
    Posts
    84
    Thinking of the same mod and having a go myself.
    Can anyone list the replacement parts?
  7. #7
    Senior Member
    Join Date
    Jan 2007
    Cologne,Germany
    Posts
    410
    Quote Originally Posted by pete.keys View Post
    S'funny.....I work in Aviation and I've seen plenty of gearboxes I wouldn't put in my bike!!
  8. #8
    Deeply Shallow Click here to find out how to Subscribe
    Join Date
    May 2006
    On the Border
    Posts
    1,859
    BMWBoxerSupplies does it from €250 upwards.
    Motoren Israel also do them... If your box is in DE.
    John
    Golden Sprout
  9. #9
    Join Date
    Apr 2008
    West Yorks
    Posts
    362
    What about Steptoe doesn't he do it keep it in the family!
    http://www.gsshop.co.uk/
  10. #10
    Grumpy Ole Git! Click here to find out how to Subscribe
    Join Date
    Feb 2007
    Deepest, darkest Long Bennington.
    Posts
    573
    Quote Originally Posted by slowkitty View Post
    You will need access to a couple of special tools, the puller for the flange on the output shaft, a shimming plate, a depth micrometer and a selection of shims at the very least as well as a certain amount of knowledge and a feel for gearboxes. Access to a 30t hydraulic press would help as well if you are thinking of changing gears and bearings.
    cheers,
    cheers,
    Duncan
    '07 R1200GS
    '82 R80 being Cafe Racered!
    '82 R80G/S
    '92 R100GS(PD)
  11. #11
    Senior Member
    Join Date
    Mar 2010
    Nelson New Zealand
    Posts
    245
    Quote Originally Posted by Redboots View Post
    John
    I just clicked on the above link to the motoren israel site & the virus protection gave a loud ding ding ding & said it detected a virus & aborted the connection. I don't know ocmputors very well but thought I'd give a heads up
  12. #12
    MC aeternum
    Join Date
    Aug 2008
    No satellites available, are you indoors?
    Posts
    9,157
    Quote Originally Posted by Padmei View Post
    Good call.
    They've either been hacked or their website has died for some other reason, but the page just returns a scripting error.
  13. #13
    Join Date
    May 2006
    On the Border
    Posts
    1,859
    Quote Originally Posted by MattW View Post
    Good call.
    Odd. Works AOK for me.
    It uses Javascript and may be trying to get you to install the latest Java.
    Also works in Firefox & Seamonkey but not in Iron
    Have you got that AVG site scanner running? Piece of poo.
    John
    Golden Sprout
  14. #14
    Join Date
    Nov 2006
    Kirkliston, Scotland
    Posts
    1,829
    Hi,
    I've rebuilt a few and have all the necessary tools.
    I haven't heard any complaints from 'Bumpmuncher' or 'Seancb' (now known as 'R100-7' or something ).
    I put the taller 5th gear in to Sean's box, but I haven't ridden his bike so can't comment on the difference.
    If you get stuck give me a PM. I only charge for parts - about £150 for a full set of bearings, seals, springs & gaskets. Add £50.00 if you want the circlip mod (though I may be able to do that myself now that I have carbide cutters for my lathe).
    Obviously any other parts/jobs required will be charged at cost.
    I'd prefer to wait until after the New Year as I have a Toyota Landcruiser Transfer box undergoing repair for a fellah in Somerset (see where hobbies take you ).
    Bob.
    The BMW R100GS - Truly Unstoppable
  15. #15
    Join Date
    May 2007
    wet end of A133
    Posts
    1,746
    yup my gear box is still going strong slick and smooth (as long as you dont try to change gear too quickly) only minor issue it has had was the output seal got a bit leaky. soon sorted with new seal. no problem scince. (afaik you can have the same problem from pro gearbox builders) Bob provided a very professional service and didnt take months. I would have no problem using his services again Thank you again voyager
  16. #16
    Join Date
    Nov 2006
    Posts
    1,829
    Click here to find out how to remove these ads
    Quote Originally Posted by bumpmuncher View Post
    Thanks for the testimonial, its good to get feed-back (good or bad).
    Bob.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
