S10 x GSA Direct Comparison
As an owner of both bikes ( 2009 GSA with 28000 km and a 2011 S10 with 3000 km ) and after following this thread for some time I decided to make a practical comparison between them.
I have more than 230.000 miles riding experience, most of it on GS/GSA bikes, mostly on long distance journeys through South America, Asia and Africa.
As a basic point I do not consider both bikes capable of any off road real travel. I usually use the off tarmac term when riding in gravel, dirt and sand roads.2222
The test
With my son I took both bikes from Sao Paulo, Brasil ( where we live ) to San Pedro de Atacama in Chile and back.In order to test the bikes in all conditions we switched bikes every 200 miles.
This is a 7000 KM journey, 80 % on tarmac and the rest on gravel, dirt and light sand roads. We faced temperatures between 40 and -2 degrees Celsius (104 28 F ) and altitudes from sea level up to 5000 meters ( 17000 feet ) when crossing one of the Andes passes.
Both bikes had the same tires ( Tourance for tarmac and Karoo T for off tarmac ), new brake pads, oil and filters. The GS has all the options ( ABS, ESA, ESC etc ) and the S10 the standard package that includes ABS, traction control and engine mode.
Both bikes has 38 liter Zega Pro panniers and assorted protection gear from Touratech. The S10 carried also a 3 gallon Rotopak fuel tank that I never used. Each bike was loaded with around 36 kilos of luggage.
Some numbers
Total mileage: 6998 km/4375 miles
GSA Fuel Consumption: 388 liters ( 18 km/liter- 42 mpg )
S10 Consumption: 368 liters ( 19,5 km/ liter -44 mpg )
( the overall mileage is low due to very steep and twisty roads to cross the Andes pass and the low speed/third gear all day ride through sandy roads in the Atacama desert. Both bikes are capable of 47/50 mpg runs on tarmac)
GSA Oil Consumption : 3 liters
S10 Oil Consumption: 0,5 liters
S10 Water Consumption: none
Overall Impressions
Steering
Although both bikes has basically the same weight, the S10 feels lighter on low speed maneuvers and heavier on medium to high speed turns. Although heavier, the steering seems to be more precise than the GSA, specially on bumpy tarmac roads.
Braking
The S10 brakes are in another league. I always believed that ABS was only usefull in the tarmac and it really annoyed me that the S10 had no “regular” way to switch off the ABS. During this trip I never switched off the ABS and its intervention is so seamless that you hardly notice it working. If there is an aspect where the S10 shines over the GSA is in the braking- traction control aspect. You must adapt your riding to this braking system, in order to use the interlinked braking system to its best. It took me two days dirt riding to really get used to it. The GSA brakes are also very good but IMHO Yamaha system is much better.
Traction Control
Also here the Yamaha system is better. After a few days, used it almost the time on mode 2 except on very twisty tarmac sections , full of diesel spills from the trucks. Different from the GSA system most of the time you only know the system is working because of the light. You feel nothing on the engine noise or riding attitude. I never switched it off. Both ABS and traction control worked perfectly on the Karoo tire in both bikes.
Driving Mode
The S10 has the driving mode switch. I leave it in the S mode. You can achieve the same effect with wrist control.
Ergonomics
Aside the original seat, the GSA offers a better ergonomic position for the rider. Wind protection, controls positioning are better than the S10’s. The original seat of the |Yamaha is better that the GSA. All the electronic adjustment of the GSA ca\n be made from the left handlebar, while the S10 has the engine mode on the right handlebar and the rest directly on the front panel. I find the GSA more comfortable on rides above 600 km / day.
Front Suspension
On the tarmac I prefer the GSA system specially because of the lack of diving under braking. Off tarmac the S10 is more compliant to the road and specially better on sandy roads.
The S10 suspension is more adjustable ( although not at the flick of button ) but I usually leave it at the same setting all the time, ie preload at 3 and compression and rebound at 4 clicks
Rear Suspension
My impression is that both are at the same level ( considering the standard shocks ) Again the S10 suspension is more adjustable ( although not at the flick of button ) but I usually leave it at the same setting all the time, ie preload at 3 and rebound at 6 clicks
Rear drive
Both work well, but on a previous GS I had a drive failure at 15.000 miles. I think that the double swingarm in the S10 is more reliable on the long run. To soon to say anything.
Engine
From the technical point of view the S10 engine is much more advanced than the boxer. The side radiator works well.My trusted mechanic says that the S10 engine is awfully limited, meaning that it could deliver easily 130-140 hp only dealing with the ecu and fuel injectors, specially if running on ethanol. It has an annoying “gap” around 3500 rpm, but it seems something related to the injection map and could easily be fixed with Power Commander.
It takes bad gasoline ( low octane ) with no problems. This bad batch we got was exactly when crossing the high altitude pass ( 17.000 feet Paso de Jama ) and although you could feel the power loss there was no knocking at all. The GSA boxer engine complained a lot ( pinging) and was really running very hot.It looks like the ECU+ knocking sensor could not deal with high altitude and bad gas at the same time.
By the other way the boxer engine is the “ character “ of the GSA. It is reliable and it is for ever linked to the GS brand. I just love this engine, so my analysis is biased here.
Rear Frame
To soon to say anything about the S10 rear frame sturdiness. The GSA with heavy panniers usually cracks when riding off tarmac..
Price
At least here in Brazil, the GSA costs US$ 50.000,00 and the S10 costs US$ 34.000,00
Service
Number of BMW service centers between Sao Paulo and San Pedro de Atacama= 0
Number of Yamaha service centers between Sao Paulo and San Pedro de Atacama= 30+
Parts Cost
GSA rear shock in Brazil= US$ 2.857,00 ESA
S10 rear shock in Brazil= US$ 975,00
Labor Cost
BMW labor cost per hour: US$ 100,00
Yamaha labor cost per hour: US$ 50,00
All things considered I consider the S10 a better bike to long distance travel. Character by character the GSA is unbeatable. I will keep both, but from now on will travel with the S10.
