Are these supposed to take a long time to warm up and run rough until they do warm up properly ?
95?..or..97? No fucking Idea...never noticed the slightest difference in the Harleys....just throw in what's available.....
Pump this, pull that, tweak the other, stand on one leg for half hour. Fuck all that, buy a Twin Cam – Job done.
My issue is the resistance part of the choke has stopped resisting.
So I have to sit and hold it out !!... I'll put it on the list...
Piece of piss to adjust. There's a plastic nut and lock nut on the back side of the bracket the choke cable's mounted on. Just slacken and adjust
I only ride mine when it's really warm.
Ive ordered new plugs, leads and a air filter but where should i go for a carb rebuild kit ?
just a thought but if it runs rough, when warmed up, have you checked for carb icing in this weather, I always use fuel adative in this weather, makes a hell of a difference to the running.
