Hi,
Does anyone have the heated clothing with the three stage controller and a multimetre??
If you do could you check if what happens when you choose the various level settings whether or not it simply alters the voltage being fed to the garments??
So if you switch on with a multimetre connected and select level 1 does it show like 7v, then level 2 is it 9v and then level 3 is it like 12v??
I am also wandering if its the case then if i was to get a simple heated grip controller would it then allow me to vary the power to the garments with ease of adjustment from the handle bars?? Or could you tap into the BMW heated grips to power them?? I will test the levels on the bike heated grips my only concern would be to relay control them but varying voltage would be a problem.
Mark
Mark
