DaveH
Been looking through the threads regarding PDA fitments and have finally taken the plunge and fitted one to my 1150.
Thought I'd share a few of the problems & solutions ..
Setup is a Dell Axim X51v (the 640 x 480 screen res one) in an Otterbox 3600.
Have a 4gb CF and 4Gb SD card installed so plenty of memory. (tried an 8gb SD and it will not work...doh!)
Am running Pocket Music Pro software as it's skinnable and has big buttons so it's easy to use on the bike...(have designed my own skin which has no frills, just big buttons for the menu items I need...see picture...BMW logo is the play/pause button in which the blue bits of the roundel go green whilst it's playing).
Powered up via a 5 volt dc-dc reducer under the rear of the tank, wired into the fuse box power supply, and switchable from the instrument binnacle. Did this so I can start the bike and then switch over to 'mains' power to avoid power spike horror stories I read on the forum.
Connections in/out of the otterbox are via an autocom EL7 lead cut in two...socket end wired to the bikes electrics/ autocom and plug end wired to the power in and audio out plugs of the PDA. (used green/black wires for power and std red/white/bare for audio)
Problems came with the electrical feed to the PDA which was corrupting the audio signal...quick call to Autocom and one isolated music lead (part No. 1314 - £28) later and it all works a treat....
Can be disconnected and removed from the bike in seconds due to the RAM mount and autocom plug/socket setup.
Also running tom tom navigator and memory map software on the unit which connects via a blutooth GPS receiver. (Still prefer the Nav II unit for long trips though cos i can set the routes up on the computer in advance.)
Hope it's of use to someone....if anyone is interested in more details pm me
Dave H
Dave H
