Nippy Normans supply Touratech, Wunderlich and many other makes of accessories. New and secondhand BMW parts  The only BMW motorcycle dealer for Cambridgeshire and South Lincolnshire.
Go Back   ::. UKGSer.com .:: > Technical & Rider > Equipment & Toys > GPS Info > Zumo 400/500/550
Register FAQ Members List Calendar
Reply
Thread Tools Display Modes
Old 15-04-07, 21:03   #1
Python
Posts: n/a
Zumo Powerlead with Canbus Fitment Q
Hi there,
I have purchased a Zumo 550;and a extra power lead from Motorrad Concepts with the Canbus connector.
Q. where does it plug into - thought it was the Power socket until I got the lead and offered it up - too short and wrong type . So anyone else fitted it on the R12GSA???
J
Old 15-04-07, 21:39   #2
Stumpy
Subscriber
Click here to find out how to Subscribe
Stumpy's Avatar
Hiya J
Between the headstock and the front edge of the top of the tank cover to the the left of the top of the front shock
There is a wee socket tucked in amongst the wiring loom, it may have a blanking cover on it.
Click the smaller pic in this link to view the area
http://www.motorradconcepts.com/esho...min/untitled/#
Stumpy
Stumpy is offline   Reply With Quote
Old 16-04-07, 08:48   #3
Python
Posts: n/a
Quote:
Originally Posted by stumpy View Post
Hiya J
Stumpy
Cheers Pal,
Did not even think of hoping back on to their website for a look. I had all the panels off looking for something to plug it into and it was right under my nose hiding under a blanking plate!!
J
Old 18-04-07, 12:44   #4
OBisss
Member
Zumo Power lead
Hi Python, I was checking out the little socket on the loom. The cover on it is a bugger to get of. I had to stick a small screwdriver in to the side of it to release it. I thought the cable was a bit expensive ( near £40 ) for all it is. Think i will wire mine direct to the battery. OBisss
OBisss is offline   Reply With Quote
Old 19-04-07, 16:57   #5
Rigormortis
Posts: n/a
I did, but I might undo it because as son as you insert the Zumo into the craddle she powers up. A bit like hot-wiring accessories to a PC. Not sure whether this was related but I had my Zumo for a week before it gave up the ghost - wouldn't power up anymore not even via the mains, USB or the car craddle. The nice people at MNC sent me a new one within a week.
Old 19-04-07, 22:11   #6
Robin
Half-attractive.
Robin's Avatar
I learn something every day!
Just been to have a look at mine. Which bit of the cover comes off? Is it just the top flat bit of the cover? Or the whole black cup-shaped bit?
Thanks,
Robin.
__________________
I'm tired of giving a reason when the future is what we believe in.
Robin is offline   Reply With Quote
Old 19-04-07, 22:35   #7
blobbs
Subscriber
blobbs's Avatar
Thanks,
Robin.
The whole black cup-shaped bit. It helps if you cut the tape which holds it to the headstock
__________________
blobbs
blobbs is offline   Reply With Quote
Old 20-04-07, 21:37   #8
grez
Subscriber
grez's Avatar
What is a Canbus model and how can you tell without taking bits off ?
grez is offline   Reply With Quote
Old 20-04-07, 21:39   #9
John Armstrong
Where next
John Armstrong's Avatar
Quote:
1200 GS / GSA in short.
John Armstrong is offline   Reply With Quote
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
