Greetings oh wise ones.
Bit of a creak from the rear end today which I thought might be one of the pivots needing a bit of WD40. Then I checked for play across the rear wheel and ... yep there is a bit. Not a lot but it is perceptible.
I've checked the OEM site and done a search here and the likely suspect seems to be the large ball bearing on the crown wheel or is it safer to replace that AND the taper roller on the other side?
The bike's done 17k miles.
