28-08-07, 13:32
#1
Subscriber
How to make a Canbus GPS cable for a 1200GS
You will need
1 BMW canbus plug(If you have trouble finding one PM me I can get them)
1 GPS power cable
Small amount of 4-5 mm and 3-4mm heat shrink
solder
soldering iron
heat gun
wire strippers
wire cutters
Unroll the GPS cable and cut off the inline fuse. The canbus system will protect the GPS unit. If you really really want to keep it in but I don't feel there is any need.
Thread the end of the GPS cable though a piece of 5-6mm heat shrink about 15 cm long then bare the ends of the wires
On the BMW socket there are 3 yellow wires numbered 1,2,3.
1 is negative/earth
2 is spare/pulse
3 is positive/ live
Cut number 2 short but not too short you want to be able to tuck it in the heat shrink later. Trim 1 & 2 thread on the 3-4 mm heat shrink as shown
Tin and solder the wires Black to wire 1 Red to wire 3
Cover the joints with the heat shrink and gently play the heat gun over them
Slide the larger piece of heat shrink up over both joints remembering to tuck the tale of wire 2 in the top and repeat with the heat gun
Thats the cable complete
The cable plugs into a matching socket attached to the wiring harness located around the headstock. It is covered with a black blanking plug and can be hard to find. The blanking plug has a sprung clip at its base which needs pressing while you remove it.
Regards
Stumpy
29-08-07, 13:31
#2
Subscriber
canbus
Great pictures, really clear. But wotz it for ????? Wotz the benefit?????
30-08-07, 15:53
#3
Subscriber
Quote:
Hiya
It provides an easy "switched" feed for any sat nav systems. As the socket is in the headstock its fairly easy run for the cable. no running wires under the tank to the battery etc. Easy to remove once you sell the bike etc
Stumpy
03-09-07, 09:55
#4
Subscriber
There was quite a lengthy discussion re using the BMW sat nav socket which prompted me to do a 'How To' a few weeks back:
GPS Sat Nav Power Connection
......includes wiring diagram extracts, locating the socket and other stuff, in addition to what's here, that may be of use.
Here's the thread I mentioned, some comments/opinions worth noting:
Taking power from the BMW GPS socket
09-10-07, 12:52
#5
Thanks for the guide. It didn't take long to make up the cable, and I could easily get to the Canbus feed without removing any panels
10-10-07, 02:59
#6
Dood'
Thanks Stumpy
Managed to get a canbus plug from Southport Superbikes who keep them in stock
So with your excellent instructions I should be able to accomplish the task
__________________
The purpose of man is to live, not exist !!
I shall not waste my days in trying to prolong them..........
I will use my time !!
G/S and 1200GS
10-10-07, 04:33
#7
Compulsive tinkerer........!
Quote:
Errr.....who should be able to accomplish the task.
__________________
"You only need two tools: WD40 and duct tape. If it doesn't move and it should, use WD40. If it moves and it shouldn't, use duct tape"
Sorry, but if it hasn't got wheels, or a pair of tits or if its not covered in chocolate, then quite frankly, I'm not really that interested.....
I'm a fiddler, I like to turn screws just because they are there.
12-10-07, 10:41
#8
Dood'
Couldn't rsist
Quote:
Originally Posted by BTBR
Of course I knew BTBR would do a perfect job   with tea and biscuits of cours  Mind more impressed with his pedal cycles than any GS
Thanks, Alan.oh and it all works
__________________
G/S and 1200GS
15-10-07, 04:20
#9
Senior Member
Thanks for this info. I intend to do mine later this week.
03-11-07, 08:15
#10
Senior Member
Maybe someone could start selling these already made up. For people like me who are crap at anything technical. Plus I would have to go out and buy a soldering iron, and all the other bits.
03-11-07, 12:24
#11
part number 80 00 0 611 656 (£8.52)
i'm about to buy some of these and do this myself. i went to a dealer today and they denied all knowledge of this part, but i'll be taking a print of that in next time.
gingercoastie, the problem is that they are often different for each GPS. if i can find a source of the plugs i'll make you one. you'll have to post me your cable and £8.52. geeks have soldering irons
03-11-07, 12:49
#12
Senior Member
I ordered my Zumo this morning, when it comes I will pm you for the address.
05-11-07, 01:01
#13
Brilliant info, thanks very much.
Quote:
Originally Posted by geek
[IMG]
I phoned Coopers of Tunbridge Wells re this part, about 6 weeks ago. Spoke to a really helpful mechanic who told me the specific part varies depending on the GS model year - but to come along (about 70 mile round trip), they'll order the part and show me where it fits on the bike.
I eventually got there a couple of Saturdays ago, no sign of the mechanic nor the guy on the service desk that I normally deal with - only 2 very unhelpful gents who told me this part did not exist, that if I wanted a second (gps) accessory socket then they'd have to fit it - £100 plus the vat. Ker ching!!! No thanks, shan't be using them again!
05-11-07, 13:51
#14
Learning fast
If it's just the yellow end that connects to the bike - if you become a subscriber to this site you can PM Stumpy who can probably help
If you need the end that plugs into your sat nav post up what model you have and someone may be able to help.
I found the cable for my garmin 2610 at Amazon for a very reasonable price!
06-11-07, 12:07
#15
Senior Member
nice thread! Wheres the best place to get a heat shrink kit from? Halfords?
Tony
06-11-07, 23:31
#16
Learning fast
Quote:
Tony
Maplins do a range in different diameters.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
