Consolidated: GPS mounts and connections
So today I had time in the workshop, so a chance to locate the mythical GPS Connector on the F800GS. I've seen threads for the 1200GS and 800ST, so I figured there'd be a fair chance...
To get under the fake tank, you need to remove the seat and six torx bolts. Four on the top tank panel, and two either side of the headstock, mounted in the black plastic that forms part of the ignition/socket assembly:
The tank panel now lifts straight off but be
careful of the power socket wiring underneath:
A closer look at the power socket wiring connector:
The wires are attacked with a spring clip. You have to press down with your thumb to release it, then pull straight off the socket:
Ooh look, what is this mysterious black box thing attached directly on top of the battery?
Pull it out of the mounting clips, and remove the black cap. There is another spring clip holding the black cap on. And inside? This:
Which is our very obviously placed GPS connector. To connect your GPS unit to this can-bus controlled switched supply that stays on for a few minutes when you turn the engine off, you will part number 80 00 0 611 656 from your friendly local BMW Dealer:
To make the cable, follow Stumpy's excellent instructions on
this thread
While the tank panel is off, we can look at the underside, and see a cutaway near the ignition for mounting of a second power socket. The black plastic moulding on the top side won't be shaped around it like the original, but at least BMW have made it easy to add a second socket:
I should also mention that the underside of the seat has space for a BMW First Aid kit, and has the basic tool kit mounted in there (spanner, torx key, screwdriver). And while we're here, let's have a look under the seat:
Not a lot of room under there. On the Single 650GS the tail piece had a bit of space, which is now loaded with this:
I don't know if that is alarm or ECU. If you have a F800GS with no alarm, tell us if you have this box
My Tesco trips will only be for the essentials:
Hope that helps someone
