Nippy Normans supply Touratech, Wunderlich and many other makes of accessories. New and secondhand BMW parts  The only BMW motorcycle dealer for Cambridgeshire and South Lincolnshire.
Go Back   ::. UKGSer.com .:: > The Bikes > BMW > 1200 GS Hexhead
Register FAQ Members List Calendar
1200 GS Hexhead Info, photo's, tech spec.... etc
Reply
Thread Tools Display Modes
Old 17-10-08, 21:10   #1
beemercarl
Posts: n/a
Power commander
Has anyone put a power commander on the R1200GS .
was it any good? Where did you get it from and how much was it.
Many thanks
Old 17-10-08, 22:44   #2
Schtum
Iconoclast
Click here to find out how to Subscribe
Schtum's Avatar
I have one but I haven't fitted it yet.
I don't know yet.
It was a birthday present from my wife.
Haven't a clue.
In that order....
Schtum is offline   Reply With Quote
Old 17-10-08, 23:18   #3
Pressurized
Senior Member
Location: Was North East, then bordered on North, now more Easterly
Quote:
Originally Posted by Schtum View Post
Haven't a clue.
Never a truer word spoken!
Pressurized is offline   Reply With Quote
Old 17-10-08, 23:22   #4
Schtum
Iconoclast
Schtum's Avatar
Quote:
**** off.
Old 18-10-08, 10:30   #5
AndyW
Subscriber
AndyW's Avatar
Many thanks
I have a Wunderlich Power Controller which is pretty good but only serves to allow you to add fuel in 6 modes (throttle ranges/rpm bands)......Power Commanders are much more sophisticated with pretty much unlimited performance 'tuning' possibilities (with the aid of the right equipment and a dyno) or by 'uploading' preconfigured fuelling 'maps' to it from a laptop/PC via USB - so should perform even better.
What mods have you done to your bike already? The more modified (exhaust, air filter, air intake etc) your bike the better the benefits of a Power Commander in tuning the bike.
Prices/distributors:
http://www.dynojet.co.uk/powercommander/index.htm
R1200GS Power Commander 'Maps' (9 at the moment)
I'll be interested to hear from guys that have fitted a Power Commander as well..........might be tempted to upgrade from the Wunderlich unit :-)
Schtum - can't believe you've not got it fitted yet!
__________________
www.MotorcycleInfo.co.uk - Free Motorcycle Resources & Information + R1200GS Archive:
.....and now Multistrada 1200 Info Pages also! and loads more :-)
www.MTS1200.info
ON-ROUTE motorcycle route & trip planner
AndyW is offline   Reply With Quote
Old 18-10-08, 12:02   #6
beemercarl
Posts: n/a
at this moment mybike is standard, thanks for the advice
Old 18-10-08, 12:09   #7
Blackal
Subscriber
Blackal's Avatar
Quote:
The Wunderlich units are just re-labelled "Techlusion" units - available from the USA for about half the price.
If you read up on them (and the Power Commander) - you realise, that for most (if not - all) - that additional fuel is what is required due to the lean-running nature of modern engines.
Al
__________________
Sorry, I tuned you out for a minute there - were you still whining................?
Blackal is offline   Reply With Quote
Old 18-10-08, 15:07   #8
prop
Subscriber
prop's Avatar
I have fitted a Power Commander to mine, an 08 GSA. Really pleased with it. Vast improvements through out the rev range, just nice to ride, mid range grunt is fantastic. I bought it from Dynojet UK, they retail about £270, but they fitted mine and spent about 3 hours with it on the dyno creating a map which they will put on there website for downloading. Bike spec is K&N filter, Remus headers with std can.
Well worth the money.
Prop
prop is offline   Reply With Quote
Old 18-10-08, 19:00   #9
Pressurized
Senior Member
Prop
Did you get a dual map - i.e. a map for each cylinder or just a single one?
Old 18-10-08, 19:13   #10
Budweiser
Senior Member
Can it really make that much difference onyack
Budweiser is offline   Reply With Quote
Old 18-10-08, 19:16   #11
Slowdown
Senior Member
Spend the money on some decent training - you'll go much much faster than you will spending a shed load on a box of smoke and mirrors.....
Slowdown is offline   Reply With Quote
Old 18-10-08, 19:22   #12
Schtum
Iconoclast
Schtum's Avatar
Quote:
Yes. I had one on the VFR which made a big difference to the throttle response and mid range grunt.
Old 18-10-08, 19:23   #13
BeemerBaz
Senior Member
Except for the twat riding it
BeemerBaz is offline   Reply With Quote
Old 18-10-08, 19:38   #14
Budweiser
Senior Member
Mike I meant to a GS I have one fitted to my Mille R and yes it makes a big difference
Old 18-10-08, 19:50   #15
Schtum
Iconoclast
Schtum's Avatar
Ahh....ok I'll let you know when I finally get round to fitting mine. I primarily got it because I was a bit concerned that with a full Remus fitted, my engine might be running a bit lean at times.
Old 18-10-08, 19:53   #16
prop
Subscriber
prop's Avatar
[quote=Pressurized;1575134]Did you get a dual map - i.e. a map for each cylinder or just a single one?
I got a dual map. I was shocked at how lean the GSA was at certain revs. The map shows having to add 26% fuel at some points but also taking away 10% due to over fuelling in others.
I was not chasing power just the fuelling being better. I think the 08's are worse than the older ones for fuelling and the tech guy said it is the worst 1200 boxer he has seen for lean running.
It is a different bike now.
Prop
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
