forget harleys.....
Nick Marshall
Shropshire
you need a Gunbus...:eek: its about a 5 ltr V twin....
another photo...
there you go......
another view
ordering mine tomorrow.....:augie
more info
Technical Data
Engine:
2-cylinder; V-type arrangement
Cylinder angle: 45°
Stroke of piston: 176 mm
Boring diameter: 156 mm
Piston capacity: 6728 cm³, 410 cu inches
Compression ratio: 8,7 : 1
Maximum engine torque: 710 Nm at 1900 RPM
Transmission:
3-gear sequential transmission with reverse gear
Clutch:
3-disk, sintered metal dry clutch
Diameter: 140 mm
Hydraulic operation
Driving gear:
Primary driving gear: duplex roller chain, 1"x 11/16"
Secondary driving gear: single roller chain, 1"x 11/16"
Chassis:
Steel tube frame; 25CrMo4; TIG welding
Steering head angle: 65°
Steel tube trapezoidal fork; 25CrMo4
Mixture control:
2 single throttle valves; 70 mm diameter
Sequential fuel injection; lambda-controlled
Regulated catalytic converter; dual ignition
Electronic engine management with switch-off slip control
Tyres:
Front: 38” diameter; 11” width; Manufacturer: RIGDON, Germany
Rear: 42” diameter; 15” width; Manufacturer: RIGDON, Germany
Braking system:
Front: two disks; 310 mm diameter
Rear: one disk; 310 mm diameter
Lubrication:
Dry sump lubrication
Dimension and weights:
Total length of vehicle: 3450 mm
Wheel base: 2410 mm
Total height: 1480 mm
Sitting height: 800 mm
Total weight, empty/curb weight: 650 kg !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Subject to technical changes.
