GPS Info Tech Support :
Ram-Man
Mollers01UK |
27-08-02, 19:44
#2
Like Newton - only stupid
"route truncated"
Are there more than 50 waypoints in your route?
Russ.
28-08-02, 18:18
#3
Subscriber
Boxer is probably right. I had the same trouble with my eMap. Created turn-by-turn routes using autorouting on the PC, but when I came to download them, they were truncated.
Created key waypoints (<50 per route) and used that instead.
Funny though - I'd have thought the V wouldn't be affected. Check the specs on www.garmin.com for route limitations.
29-08-02, 04:00
#5
Check that you have the latest firmware for the unit. Garmin supposedly fixed this a while back with a download. I had the same problem that disappeared after the upgrade
29-08-02, 21:04
#8
........and in answer to your next question.........
Holding down the enter key while turning the unit on will display the firmware version you are running.
This came from joining Garmin v at yahoo groups and doing a search on firmware.
Might be an idea to join yourself.
Russ.
29-08-02, 21:47
#9
Senior Member
TimD,
Just phone Garmin UK on 01794 519944 and ask for "tech support". It's always so much easier and they are extremely helpful.
Chris
30-08-02, 03:39
#10
Re: City slicker
Quote:
Originally posted by TimD
When I start up Map Source it says 4.9, so I presumed that the download had worked. What else can I check?
I know little of such matters - hardware and software I am familiar with, what is firmware????
Already covered by other posts but you're confusing the Mapsource software (version 4.09) with the GPS V unit's firmware which should be 2.08 if you have updated it correctly. Download the firmwarte fom the website at Garmin and follow the instructions if you havent done so already.
30-08-02, 18:25
#11
THANKS GUYS!!!!!
PROBLEM SORTED
SORRY TO BE SUCH A NUMPTY!!!!!!!
'tis a piece of piss when you consult the experts
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
