Hi folks,
I have an 09 GS and over the past few thousand miles there is an increasing pulsing when braking gently at low speeds. I have taken it to my local dealer twice, and both times they have test ridden it and said there is no problem and the discs are in spec. I have read the threads on here but I am now stuck really.
I feel like I am going mad. The pulsing is definitely there, to the point where it is actually uncomfortable braking at low speed (especially with a passenger). When I got home from the latest trip to the dealer I touched both discs. The right one was warm and the left a lot cooler. Is this likely to be connected with the problem, or nothing to worry about? Also, with the front wheel clear of the ground I can spin the wheel and hear that one of the discs is not right as the usual sound of the pads on disc changes once per revolution.
My next step is to take it to another dealer, but I am worried that I will get the same response. Is there any advice that you guys have or your own experiences of getting this problem sorted under warranty?
Much obliged,
Matt
Much obliged,
Matt
