Waiting on the 2011 release due this month, better be as Garmin have told me it will be and I'm off to the Alps on the 30th. £53.39 for DVD but I think it's done based on £<>$ exchange rate at the time of purchase as it's a weird amount even before VAT, if that's the case then the price will fluctuate somewhat.
Ordering via DVD as I have an imported StreetPilot and the mapping install means jumping though hoops. Having the mapping on DVD will be an advantage for that.
Based on what I've read about 660's I'd stick with your 550 until they get the 660 sorted!
If your existing maps are 4 years old this will end up being factored into what someone will pay you for your 550 anyway. A compromise might be a superceded copy from 2009 or 2010 which should come in cheaper.
Except you won't be able to get a legitimate unlock code for mapping other than what's current. As 2011 is due out this month, might already be available on a download update, I'm pretty sure that you won't get an unlock code from Garmin.
Well, for me it's a non starter as I'm not sure how I can do my hacked, yet legitimate and paid for, install with a downloaded update. Added to which; I tend to update every 2 years at best, this time around it's 3 years. Next time around I will probably have got rid of the SP2720.
Hi Greg,
Nothing, but be aware the 2011 update will not fit in entirety on a 550. You need to download onto your PC and just upload the necessary regions.
Hi Greg,
Managed to get mine on without issue... Downloaded update with Zumo connected, file automatically extracted the update and installed on both computer and Zumo without any problems...
I stripped out the voices, text and vehicles etc, but could not get the latest update onto the Zumo, I had to put it on an SD card.
Will this make the maps slower to load or throw up any other problems?
Part of my problem is I was using a Mac, not too much info around about using the Apple OS software.
