06-04-11, 15:44
#1
Disgrace, frankly.
I'll tell you why Enduro riders are hard
It's not the courage, manhandling a huge motorcycle on soft ground at mad speed, the heat or the crashes. It's putting on the f******* boots.
Out in 22 degrees for five hours today - not problem. Home to find the Astars Tech 8s I bought off Clod have arrived...40 minutes sweating, swearing, stretching and crunching fingers.
I think I may have pulled a shoulder muscle.
__________________
The Moving Finger writes; and, having writ,
Moves on: nor all your Piety nor Wit
Shall lure it back to cancel half a Line,
Nor all your Tears wash out a Word of it.
06-04-11, 18:29
#2
Subscriber
Did you put them on the correct feet?
__________________
NI Phil
2007 R1200GSA Silver - Bending the rules & ruling the bends
2006 Husaberg FE 450  - Sometimes Calculated - Usually Kamikaze
06-04-11, 18:37
#3
Subscriber
Quote:
not hard - just brighter?
06-04-11, 19:35
#4
Disgrace, frankly.
Yes, but I've not been doing enduro long. Give me another six months and I'll be dribbling whilst trying to tape them on to my arms....
__________________
06-04-11, 22:49
#5
Subscriber
Yea - my enduro riding involves lots of dribbling
I still fall off a helluva lot
__________________
NI Phil
07-04-11, 10:38
#6
opinionated, me?
There is a technique to getting Tech 8's on easily.
Mark
(on his 3rd pair now)
__________________
Just when you've got this rat race licked, here come faster rats!
07-04-11, 11:17
#7
Disgrace, frankly.
Quote:
Mark
Yes? YES?
__________________
07-04-11, 11:40
#8
opinionated, me?
You have a pm.
Mark
__________________
07-04-11, 16:09
#9
Subscriber
[quote=earthmover;2683285]There is a technique to getting Tech 8's on easily.  /QUOTE]
Undo the laces first?
__________________
Learn the rules so you know how to break them properly
07-04-11, 19:04
#10
Disgrace, frankly.
You have a pm.
Mark
So I do, cheers. One on the way back....
__________________
29-08-11, 07:04
#11
New Member (less than 15 Posts)
less pressure on the clutch
If you often have problems with sore left hand due to switch gear or using the clutch a lot, if the bike is good, you dont need to pull the clutch before switch gear up, just give some gas and then lift up your left foot, and it shouldn't cause any problems if you have the correct rmp.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
