Nippy Normans supply Touratech, Wunderlich and many other makes of accessories. New and secondhand BMW parts  The only BMW motorcycle dealer for Cambridgeshire and South Lincolnshire.
Go Back   ::. UKGSer.com .:: > The Bikes > BMW > 650 & 450 singles > F650GS/Dakar and G650GS/Sertao singles
Register FAQ Members List Calendar
Reply
Thread Tools Display Modes
Old 04-10-11, 00:12   #1
Selous
Member
Exclamation New BMW G 650 GS Sertão
From BMW
With its new BMW G 650 GS Sertão, BMW Motorrad has added a new, sporting chapter to the history of single cylinders in the BMW GS family. Whereas the G 650 GS thrilled riders with its lean, wiry off-road stature, the G 650 GS Sertão promises even more sporting characteristics, even greater off-road capabilities, and an even stronger desire for adventure.
The new G 650 GS Sertão uses the established liquid cooled, high-torque single cylinder engine of the G 650 GS with two overhead camshafts, fuel injection, and double ignition. Its 652 cc displacement delivers 48 hp at 6500 rpm and a max torque of 44 ft/lb at 5000 rpm.
Selous is offline   Reply With Quote
Old 04-10-11, 06:09   #2
team3xh
New Member (less than 15 Posts)
BMW Motorrad Deutschland
Geländetauglicheres Fahrwerk, optimierte Tourentauglichkeit und dynamisches Design.
Wurde das Fahrwerk der G 650 GS mit Schwerpunkt auf den Landstraßenbetrieb und leichte Geländeeinsätze entwickelt, so bietet die
Sertão im Hinblick auf die Offroad-Tauglichkeit ein deutliches Plus durch längere Federwege sowie eine straffere Abstimmung. Ergänzend dazu ist sie neben Drahtspeichenrädern ab Werk reichhaltig ausgestattet.
team3xh is offline   Reply With Quote
Old 04-10-11, 12:22   #3
stuartw
Subscriber
Click here to find out how to Subscribe
stuartw's Avatar
https://skitch.com/stuarthw/f6bna/20...lation-youtube
21 inch front , wire wheels, more travel - just what people have been asking for on this forum!
stuartw is offline   Reply With Quote
Old 04-10-11, 13:32   #4
Farmer Palmer
Subscriber
Farmer Palmer's Avatar
Sertao.....!
Quote:
Originally Posted by mikeschofielduk View Post
That looks spot on but have they fixed the problem of the front forks breaking and causing the front wheel to fall off. I saw it reported on here some weeks ago.
I've read about that particular bike in America with the broken front fork axle mount but i've not seen any others on the G650GS forums.....!
Hopefully that bike was a one off.
There were some early 2001 F650GS's with a similar problem but that was a different fork leg casting design. If the G series had a similar fork problem there would have been more failures reported by now.........One is one too many though!
I like the Sertao version of the G650GS and the taller height and longer travel suspension would suit my 6' 4'' height. Excellent fuel economy and good gravel road ability sounds good too especially with the 21/19 spoked wheels.
FP.
__________________
East Lothian.....Birthplace of Scotland's flag! AD.832 I'm voting.............YES!(i don't want independence)
Farmer Palmer is online now   Reply With Quote
Old 04-10-11, 16:17   #5
siwhite
Subscriber
siwhite's Avatar
Quote:
Originally Posted by rt001 View Post
Am I the only one that thinks the G650 is a piece of crap?
It sounded (and went) like a lawnmower.
No, you're not alone.
I used to ride an F650GS, and changed to an F800GS. I had a G650GS as a loaner bike while mine was serviced (despite asking for an R1200 test bike) and only managed to ride it down the road before taking it back and demanding a different bike. It was foul - worse than my old F650, and had really horrid switchgear. It just doesn't feel acceptably modern - silly flat bars and it does sound like a tractor mower when started.
siwhite is offline   Reply With Quote
Old 04-10-11, 17:56   #6
rce
Subscriber
rce's Avatar
Lot of unexplained issues with that report...
Bent axle and bent fork leg just don't fit with the reported circumstances.
__________________
Alan
rce is offline   Reply With Quote
Old 04-10-11, 18:04   #7
rc mad
Senior Member
some more pics
Personally I think I'll keep my 'old' Dakar, bmw could have made the bike so much better for not much money. About the only thing i like is the new clocks. The biggest let-down is that they are still using the same damper rod 41mm forks that have been on the bike since it first came out.
i ended up fitting a set of 46mm usd forks to my dak, along with a wilbers rear shock. it's a great handling bike now
rc mad is offline   Reply With Quote
Old 04-10-11, 18:41   #8
Scythian
Senior Member
I got sent this link this morning. Site has memory-heavy 3D image of the bike plus all the specs if you're interested. They are saying its their new Funduro:
http://www.bmw-motorrad.com/com/en/i..._overview.html
Scythian is offline   Reply With Quote
Old 04-10-11, 19:28   #9
rce
Subscriber
rce's Avatar
Quote:
Originally Posted by Seamaster View Post
Does it have the same engine as the x series of bikes or the old 650 engine that was in my 650 Dakar from 2004 ?
According to the spec the engine is the same as the standard G650GS
I notice the fork legs look to have the exact same design as the standard G650GS which presumably means they don't have much concern over strength given that this is more off road oriented.
Front mudguard has gone to make room for the bigger wheel.
__________________
Alan
Old 04-10-11, 22:11   #10
Farmer Palmer
Subscriber
Piece of crap and all that......!
I rode one for a bit on the ORS in Wales, and lots of people also commented (including Mr P) about how BMW have dropped the ball on this one.
I think a lot of folks are missing the point of these bikes.
It a 'cheap as chips' entry level bike not a £15k LWD 1200GSA or the latest Dakar Rallye bike.
For only £5k you get a bike a bike that's built 'down' to a price but that doesn't mean to say it's 'crap'.
So what if it's a ten year old design with a 'new' Chinese built engine that sounds like a 'lawnmower', it all works adequately. It's not brilliant, fantastic or inspiring but it will get you to work and back, go for a fortnights trip or even around the world without as much fuss as the 'bigger' GS's!
Its a bike anyone can ride whether they're 5' 0'' or 6' 4'' and it's not intimidating to novice riders either.
If I didn't have my GSA30 i'd be more than happy with the wee G'!
FP.
__________________
Old 04-10-11, 22:18   #11
kirk71
Subscriber
kirk71's Avatar
FP.
bang on fella,
5k for a non abs model, 80mpg, cracking all round bike.
__________________
Smile......it confuses people !
kirk71 is offline   Reply With Quote
Old 05-10-11, 08:56   #12
Goose
Subscriber
Goose's Avatar
Although not the old Dakar - seems BMW might have been listening to their client's for once and brought out a remnant of the much loved Dakkie.
Handguards, Spoked Wheels is what we wanted... and BMW-SA were adamant that there was not going to be an offroad version of the 650 single and all the requests were to be available as optional extra's... at BMW premium prices.
Methinks this will be a winner... especially in Africa!
Goose is offline   Reply With Quote
Old 05-10-11, 12:10   #13
shugie
idleness personified
shugie's Avatar
Quote:
Originally Posted by Micky View Post
Get a life guys ... it's better at it's job than a 1200 is
Well at least you can go places on it
Same bike to all intents and purposes as the old F650GS and girlfriend Sue and misen done two 'Long Way Home' trips on the old 650's ... like Siberia and Mongolia, Iran and Pakistan
The only thing my G650 (which is the Chinese lawnmower engine) isn't as good as my 1200 at is going down the motorway with a full load of kit. Around town, or on the local lanes, it's really good, and stunningly economical. £8 a fill for 120 miles or thereabouts.
Sold at the right price, this bike could do very well for BMW, especially if the seat height isn't too daft.
__________________
No politician can be trusted.
Broken networks fixed in Berkshire - www.rgnetworkengineering.co.uk
shugie is offline   Reply With Quote
Old 05-10-11, 15:06   #14
rce
Subscriber
rce's Avatar
But have you actually ridden one?
Have you ? I have, and I know Chris has. I reckon it is a brilliant bike, really good fun to ride. I have done 300 odd mile days on our G650GS and really enjoyed it, it lives for the smaller A roads and all roads below, yet can still manage on the Motorway if really required.
When you add in the purchase price, the mpg, and the pure grin factor these are brilliant bikes.
__________________
Alan
Old 05-10-11, 15:09   #15
The Nutty GSER
Subscriber
The Nutty GSER's Avatar
Yes, and I didn't like it! Just my opinion; I'm sure it's a great bike for some.
The Nutty GSER is offline   Reply With Quote
Old 05-10-11, 16:22   #16
Farmer Palmer
Subscriber
Keep it coming.......!
I'm so loving the words.....Tractor mower, lawn mower and my favourite is 'really horrid switchgear', even Mrs P was impressed.....!
Perfect words that really do describe the very exclusive and 'handbuilt in Berlin' HP2 Enduro I owned for three years before my GSA30 and to be honest my GSA30 isn't that much better. At £15k for a full spec one I doubt I could say it's three times better than the 'wee G'
Mrs P's G650GS/FL is just more 'fun' to ride and at a third of the price of a 'real' GS it's going to win everytime for me. Who else other than BMW builds a 650cc bike as capable as the G650GS for £4995 OTR?
Also have a look on www.f650.co.uk and compare the amount of whinging about F/G650's by their owners compared to the amount of whinging on here about 8/1200GS's
I suppose it's all about expectations.......Anyone getting their 'big BM' serviced and being given a G650GS as a loan bike will be a wee bit disappointed but what did they really expect.........It's got a 48bhp single cylinder engine with telescopic front forks and a single disc brake set up and of course 'proper' switchgear(I actually much prefer the traditional three button BMW set up but don't tell Mrs P)
One other thing that really appealls to me on a long trip has got to be fuel economy of the G650GS compared to the bigger bikes. Up to 85mpg is starting to make a lot of sense these days.......!
The F/G650GS series of bikes are also 'the' most reliable bikes ever built by BMW and it's the choice of 'no nonsense' world traveller on www.horizonsunlimited.com. Not many fully loaded R1200GSA's to be seen there except at the 'local' home counties meetings of course.
FP.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
