Nippy Normans supply Touratech, Wunderlich and many other makes of accessories. New and secondhand BMW parts  The only BMW motorcycle dealer for Cambridgeshire and South Lincolnshire.
Go Back   ::. UKGSer.com .:: > The Bikes > BMW > 850/1100/1150 Oilheads
Register FAQ Members List Calendar
850/1100/1150 Oilheads Four Valve Oil Head Boxers
Reply
Thread Tools Display Modes
Old 11-01-13, 18:31   #1
Redsprocket
Member
Red face Servoectomy....is it going to hurt doctor?
It seem's from the forum that the servo ABS gremlins have been busy the last few weeks....
I read the posts and think well mine seems ok.........
I have an 03 1150 GSA.
So..... started the winter service and adding the latest farkles, and turn on the ignition to check I'd put the front indicators back on correctly, and the bloody light flashes at 4hz and won't go out, and the servo isn't making a noise when the rear brake lever is pressed...
Now, yes the battery may not be at its best as i don't use the bike everyday , but its been on an Optimate, so seems fine, and the rear brake bulb looks ok, so bugger it must be the servo
So my question is having read the excellent sticky post on the servoectomy has anyone who's done it any additional tips, photos etc that could help, or is there anyone in the lincolnshire area who's done it that I could an come at look at, or, is it as straight forward as it looks?
Anyhow, any advice is appreciated
Redsprocket is online now   Reply With Quote
Old 11-01-13, 18:38   #2
Fanum
Contrary twat
Click here to find out how to Subscribe
Fanum's Avatar
Leave the engine off, kneel near the foot brake lever and see if you can hear the microswitch click when you operate it...it is a small sound, but should be quite distinct.
The switch can pretty easily get shitted up...a bit of a squirt of brake cleaner can often cure it, but make sure you follow up with some Lube after.
__________________
For any information or to order any LED lights, Durite or Landrover parts, please contact GERT on 07765 071063
Fanum is offline   Reply With Quote
Old 11-01-13, 20:56   #3
Redsprocket
Member
Ok, will do, let's hope that works...
Old 12-01-13, 10:11   #4
Redsprocket
Member
No, I can hear the micro switch.....
Old 12-01-13, 18:58   #5
Beagood
Subscriber
Beagood's Avatar
Had the same on my '04 recently, it was the front brake lever contacting the hand guard.
Beagood is offline   Reply With Quote
Old 12-01-13, 19:16   #6
Fanum
Contrary twat
Fanum's Avatar
Quote:
Yep, that'd cause it as well.....it stops the system completing its self check
__________________
Old 13-01-13, 13:28   #7
Redsprocket
Member
No not that either.....
I take the point on cleaning all the sensors etc though, so I'll do that first before moving on to removal of parts....
Thanks for the advice
Old 13-01-13, 13:36   #8
Fanum
Contrary twat
Fanum's Avatar
Neil (Steptoe) also did a thread on renovating the ABS unit (I presume you were referring to his article on removing the ABS in the first post?), which apparently cures most 'failures'....I'm pretty sure it's in the Font of all wisdom section.
__________________
Old 13-01-13, 16:04   #9
GADGET
Subscriber
GADGET's Avatar
Did the complete removal on my K1100LT this morning, didn't mess around, paper towels to collect any drips of brake fluid and a small pair of bolts croppers on the pipes. Three bolts holding the abs/servo unit in. Was all in the bid in less than an hour. Just need to sort out a couple of new brake lines now.
GADGET is offline   Reply With Quote
Old 13-01-13, 18:02   #10
Redsprocket
Member
Quote:
Hi, I've not seen the renovating thread, I'll search now for it, thanks. I've read the removal thread from Steptoe.
I've never liked the servo, as having poor brakes when you move the bike around with no ignition on, always seemed a disaster waiting to happen
However I wouldn't remove it if it was working fine...
Old 16-01-13, 22:34   #11
Hubs
Subscriber
Get rid of it if there's a problem. Enjoy progressive, easy to use brakes that work at a standstill, and no self check shenanigans. Best Farkle I've done!
Hubs is offline   Reply With Quote
Old 17-01-13, 10:18   #12
Steptoe
What a waste.
Steptoe's Avatar
Quote:
A K1100 has never had servo brakes.
All you've removed is an abs unit, which requires one spaner .
A very very simple job compared to a servo removal.
__________________
All your BMW servicing needs at the .gsshop.biz, including 1200 models
Recommended as an "excellent independant" in Ride magazine 2009.
Steptoe is offline   Reply With Quote
Old 17-01-13, 11:14   #13
GADGET
Subscriber
GADGET's Avatar
Neil,Hey..... it had to be simple.... if it was me doing it
Old 22-01-13, 20:28   #14
Colin
Member
servo/ABS
I followed the instructions by Dave H. on this forum last year and completeley removed the servo/ABS unit. best thing ive done. the bike is much safer to ride and the brakes have got some feel to them, the only cost was a bit of brake fluid. BMW R850R. 2003.
Colin is offline   Reply With Quote
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
