On the whole I am very happy with my BMW Navigator II and associated Garmin products, V8 and all the software updates correctly installed. The level of mapping and detail in Europe is now very good.
Leaving aside the oddity over the device’s / software inability to plot certain long distance routes, where the BMW device ran out of memory (see earlier post) I have found some real problems with V8 that did not seem to be so common on V6 or V7. These were not one-off problems and were not limited to my device alone. All of us using Garmin based navigation on the same routes, at the same and, independently, on other occasions on different routes, had the same problems. Here is my go at explaining what the problems are:
We are all familiar with the ‘spoken instructions’ not matching the screen / or what the driver actually sees on the road. These are usually limited to the software interpreting a hairpin (or similar sharp or long bend in the road map) as a junction (or maybe a fork) in the road. Hence, the spoken instruction to sometimes, ‘Turn left’ or ‘Bare left’ or 'Keep left’ on what is otherwise a simple route. We are also familiar with errors in satelite reception sometimes 'shifting' the vehicle's position off the road into a field. These I can live with.
What V8 seems to be getting wrong is the voice instructions at much more important and real junctions. These errors take several forms:
Roundabouts: For instance, entering a five-exit roundabout at six o’clock to leave at exit 4 at, say, eight o’clock. On a French roundabout this requires travel around the roundabout anti-clockwise to the forth exit at eight o’clock. This correct route around the roundabout is clearly shown on the device’s map screen and on the ‘pop-up map’, so the route is correctly entered and the device's screen is showing it correctly.
The voice instruction however says, quite clearly, ‘Leave the roundabout by the first exit’. In my French example, this would be three exits early and be at roughly three o’clock. I can only assume that somehow the device and voice are becoming confused as to which way one goes around a French roundabout. For instance, if it were a UK roundabout then the fourth exit would indeed be the first exit.
When I ignored the voice and followed the map (and road signs) around the rounabout the voice prompt quickly corrected itself. When I sailed past the exit the voice had told me to take it went on to say, ‘Leave the roundabout by the XX exit’, almost as if the voice had now realised its error and caught up with the map.
Distinct junctions or distinct deviations from one road onto another: Here I am not talking about new roads that do not (for understandable reasons) appear on the map. Rather, I am talking about long established roads, requiring, say, a right angle turn onto a fresh road or, in the case of a motorway splitting into two, a similar real deviation in the route. Here is an example:
Straight road on the map running north – south. The straight road is the A5. The plotted route and map clearly show the need to leave the A5 left, at right angles and join the B4. In other words, a significant deviation onto a completely fresh road. The voice prompt completely ignored any prompt to turn left. This means you sail straight past the junction and are only made aware the error when the voice pipes up to say, ‘Off route, recalulating…..’
The really odd thing, in one real life example of this happening, was that the voice prompt warned of the need to, ‘Keep left in two miles'. This was not an instruction to turn left in about 100 yards onto the B4, but warning of a sharp bend (see example above) on the B4 itself. Meaning that the voice instruction did not give a basic instruction to turn left onto the B4 but did warn of a bend coming up in two miles on the B4, once the turn had been made and the driver having travelled more than two miles.
A road crossing a motorway: Again this was in France. A country road crosses a motorway at right angles. The country road runs east to west and the motorway north to south. The country road ends in a Y junction. The right hand fork leads down to the motorway ie. it’s a 'ramp' road down to the motorway. The left-hand fork ‘ramps’ left and continues as a country road which proceeds to bend around to run parallel to the motorway.
The route and the map clearly (and correctly) show that the vehicle is to take the left-hand fork, down the 'ramp' continuing on the country road and to run parallel to the motorway. The voice instruction however clearly says, ‘Keep right in three hundred yards (when it should be, ‘Keep left’) and then says ‘Take ramp right’ (onto the motorway) when it should be. ‘Take ramp left….and follow the road…..’, thereby matching the map and downloaded route. It obviously follows that, had I simply followed the voice, I would have ended up on a motorway, heading God knows where, with a voice bleating, 'Off route, recalculating....'
As I said:
(1) All of these examples (and numerous others) are real life and happened over a four-day 2,000 mile trip around northern France. All of us using Garmin devices were equally troubled. Similar things have happened quite regularly in the UK and to me in Spain.
(2) The frustrating thing is that 99% of the rest of the package is very reliable, with only the occasional glitches. These occasional glitches are mostly caused by satellite reception problems, which are hardly all Garmin’s fault.
(3) The real gripe is where the voice instructions are so wrong, or missing or deviating entirely from the map and from the route installed. This leads to a feeling of unreliability and real concerns that any minute another error will be made. This feeling stays with rider and distracts from the job in hand ie. staying upright and avoiding the million and one other hazards set in the way.
(4) If Garmin are interested, I can map out and send examples where the routes went wrong. I guess that Garmin would be able to play them back with a voice prompt running to see what I mean.
Kind regards,
Richard Nash (Wapping)
Kind regards,
