ohlins spring
The Chairman
Member
Guildford, Surrey
Greetings from afar
To cut to the chase. Purchased a rear Ohlins shock with two springs. The softer one is fitted. How do I change to the standard one. Specialist job or what?
Thanks for your help
The Chairman said:
Greetings from afar
Do not consider trying to change the spring yourself!
You need the correct equipment in the form of a spring compressor and the knowledge to know what to do, it's a case if you have to ask how you should not be considering it I'm afraid.
Contact a local specialist, not an expensive job.
Enjoy the shock :thumb
That´s what I thought. Had a good look at it and then decided to ask the Guru´s. Didn´t fancy being a hero.
I´ve tried it on the softer spring and can already tell the difference. Thanks for the info.
Harris sell the tool. it's about £200 IIRC but probably has VAT to be added.
